94 lt1
Old Apr 7, 2013 | 03:23 PM
engine27's Avatar
engine27
2nd Gear
Default 94 lt1
Car has rough idle, surges at stop light, coughs under hard acceleration. I changed the MAP sensor, cleaned MAF sensor,throttle body (3 times) and air filters. Still doing the same old stuff. Need help. No codes showing
Old Apr 7, 2013 | 03:25 PM
engine27's Avatar
engine27
2nd Gear
Old Apr 7, 2013 | 05:18 PM
THE 383 admiral's Avatar
THE 383 admiral
Was this idle issue present before the part swaping????
What is your FP pressure? Did you try to clean your IAC?
To 94 lt1
