noisy brakes
Old Apr 7, 2013 | 08:13 PM
Polo Vert's Avatar
Polo Vert
Default noisy brakes
Had my car for about a month now and with the weather starting to break I've been driving it a fair amount. What is annoying though is the brakes squealing every time I hit them. The pads have plenty of life so I'm not sure why they are so noisy. Is there a particular pad I should be using that is quiet and doesn't make alot of dust? Mine is a casual use car so I don't need racing pedigree pads on it.
Old Apr 8, 2013 | 09:16 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
This pad will do the trick for you. If interested give me a call at 216-780-8825.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 8, 2013 | 10:03 AM
eatmydst1234's Avatar
eatmydst1234
Have they always been noisy? If not try a couple moderate stops down to 15mph or so so? It's worth a shot but I have had that help a lot with cars that have sat for a while.
Old Apr 8, 2013 | 11:44 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'd check all four corners to ensure the pads are "free floating"
You can also try an anti-squeal product that is applied between the piston and back face of the pad.
Good Luck
Old Apr 8, 2013 | 04:16 PM
Polo Vert's Avatar
Polo Vert
I think instead of throwing money at this setup I'll upgrade to the J55. The rotors and calipers are easy to find but where can I get the mounting brackets? Thx for all the advice so far...
Old Apr 8, 2013 | 04:43 PM
LoneStarV's Avatar
LoneStarV
Squeaky pads are fairly easy to fix. Plenty of silencer products on the market and re-bed your rotors. Cheap fix.
Old Apr 8, 2013 | 06:28 PM
eatmydst1234
The J55 would be throwing money at it. try what i said first, costs nothing at all and will help or not.
Old Apr 8, 2013 | 06:50 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Hawk HPS --
To noisy brakes
