Carbotech Performance Brakes
Old May 13, 2013 | 10:56 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old May 23, 2013 | 10:57 AM
Carbotech Adam
Supporting Vendor
Old May 31, 2013 | 09:52 PM
ZR11AB's Avatar
ZR11AB
2000 c5 targa 600 rwhp 285-30-18f/355-25-19r, 99% street, like to do 1/8 1/4 1/2 1 mile, 0-60-0 0-100-0 capabilities , on street 4-7k miles year primary use
Susp z06 springs, 35/25mm sway bars adj links, pfadt adj shocks 5f/8r firm, a4, 3.15, tt lpe
Old Jun 1, 2013 | 09:03 AM
Carbotech Adam
Supporting Vendor
I am not sure what you are looking for, a street pad or something to decrease your stopping distance from 0 to 100 to 0?
Old Jun 26, 2013 | 12:31 PM
Carbotech Adam
Supporting Vendor
Old Jun 26, 2013 | 11:18 PM
pkincy's Avatar
pkincy
I have used the early XP8 on a track/street car (my 98 LS2 402 Camaro) and the XP10 on my race car (93 Camaro Camaro Mustang Challenge car) with great success.
Excellent brakes that wear well, stop like the No 3 wire on a carrier, and don't dust as much as some.
Keep up the good work.
Old Jun 28, 2013 | 08:36 AM
Carbotech Adam
Supporting Vendor
Old Jul 9, 2013 | 11:27 AM
Carbotech Adam
Supporting Vendor
Old Jul 31, 2013 | 06:06 PM
Carbotech Adam
Supporting Vendor
Carbotech brakes utilize a ceramic and metallic construction in a range of compounds that out-perform competitive brakes. Carbotech brakes are made from compounds that offer higher initial bite, torque and fade resistance—providing consistent brake modulation and performance over a wide range of operating temperatures.
In addition, Carbotech brakes are rotor friendly, saving money and keeping your vehicle out of the service shop far longer than the competition.
Carbotech brakes give you:
• Assured stopping power
• Increased overall performance and handling
•Excellent modulation and release characteristics
•Better control entering the corners
•Longer brake pad and rotor life—up to four times longer than the competition!
•Longer rotor life
•Non-corrosive dust
Old Aug 7, 2013 | 11:04 AM
Carbotech Adam
Supporting Vendor
Old Aug 13, 2013 | 11:31 AM
Carbotech Adam
Supporting Vendor
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application. Contact info is below if you need some help or would like to order a set. Orders place direct through me receive 5% forum discount.
Old Aug 30, 2013 | 09:56 AM
Carbotech Adam
Supporting Vendor
Old Sep 6, 2013 | 12:36 PM
  #33
Carbotech Adam
Supporting Vendor
Old Oct 14, 2013 | 10:48 AM
  #34
Carbotech Adam
Supporting Vendor
From street use to the higher performance demands of track days, we'll help you achieve better brake modulation, torque and fade resistance. High-tech construction means better stopping power and a higher level of driver confidence every time you get behind the wheel.
Old Nov 20, 2013 | 03:23 PM
  #35
Carbotech Adam
Supporting Vendor
I will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly rotor friendly and contain 100% non-corrosive brake dust.
Old Nov 20, 2013 | 03:50 PM
  #36
1993 Z07's Avatar
1993 Z07
Great information Adam. I live in Salt Lake City Utah so we are just putting our cars away for the year. I would like to check out your pads next spring. Thanks for posting and educating me to your great products.
Old Nov 20, 2013 | 09:05 PM
  #37
Carbotech Adam
Supporting Vendor
I appreciate your comments. I am always here to help even if you are not using Carbotech brake pads.
To Carbotech Performance Brakes
Old Dec 11, 2013 | 01:57 PM
  #38
Carbotech Adam
Supporting Vendor
Old Dec 11, 2013 | 10:47 PM
  #39
dizwiz24's Avatar
dizwiz24
Carbotech adam...
Can you explain if your street/strip pads have any advantages vs. Hawk.
Specifically hawk hps and hp plus.
Ive heard you say your pads dust is less corrosive. That said, there is no issue with corrosion on my painted alum rims due to dust from my hawk hp+ pads.
Hawk seems to be a high target for other brake pad companies to meet.
Id like to hear about what carbotech has to offer...
Old Dec 12, 2013 | 08:48 AM
  #40
kimmer's Avatar
kimmer
C4 of the Year Finalist
