Carbotech Performance Brakes
Old Apr 11, 2013 | 11:20 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Carbotech Performance Brakes
It’s that time of year to get your corvettes out and start driving, but more importunately you need to be able to stop if you’re on the fence about new brake pads maybe we can help you out. Carbotech Performance Brakes, the world leader in Ceramic friction materials. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry that means our pads will not harm your wheels or paint on your vehicle. Please contact me with questions or to place an order.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 16, 2013 | 11:17 AM
Carbotech Adam
Supporting Vendor
Old Apr 20, 2013 | 10:26 AM
Carbotech Adam
Supporting Vendor
Old Apr 20, 2013 | 04:19 PM
Ronstar's Avatar
Ronstar
Options and pricing for Zr-1?
Old Apr 20, 2013 | 05:05 PM
Carbotech Adam
Supporting Vendor
Need more info tire, HP and so on. We make all compounds but need more info from you so, I can put you on the correct compounds.
Old Apr 20, 2013 | 06:15 PM
Ronstar's Avatar
Ronstar
421 ci, 650+ hp. 335x18 rears,285x18 fronts. Mostly street driving. Very occasional drags or parking lot races. Looking for better stopping but don't want dust and noise.
Old Apr 21, 2013 | 10:29 AM
Carbotech Adam
Supporting Vendor
The 1521 compound is what you need. Price is below. Give me a call at 216-780-8825 to order.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
$142 front $127 rear Less 5% forum pricing.
Old Apr 26, 2013 | 10:27 AM
Carbotech Adam
Supporting Vendor
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes™ are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application.
Old Apr 26, 2013 | 11:29 AM
mszietlow's Avatar
mszietlow
Old May 3, 2013 | 10:37 AM
Carbotech Adam
Supporting Vendor
Friday
Old May 3, 2013 | 10:58 AM
mrc24x's Avatar
mrc24x
Hi Adam
I currently run Hawk dtc-60 front/rear on my race C4 with AP 8350 front calipers and stock rears.
What would you recommend in Carbotech's line? I'm looking for better rotor wear and initial feel. No ABS in the ole C4.
Price also please...
Thanks,
Matt
Old May 3, 2013 | 11:06 AM
Carbotech Adam
Supporting Vendor
Originally Posted by mrc24x
Hi Adam
Thanks,
Matt
Matt, I would use XP20 front $267 and XP10 rear $178 Less 5% forum discount add $40 for pre-bed.
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, the most linear torque curve to date and excellent fade resistance the XP20™ leads the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. The XP20™ as with other Carbotech™ compounds is very rotor friendly. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
When Carbotech™ unleashed the XP10™ to the general public it was an instant success. XP10™ immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite friction material with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1650°F (898°C). Due to the high level of friction and bite, this material is recommended for cars weighing around 2,900lbs or less. XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Old May 3, 2013 | 11:14 AM
mrc24x's Avatar
mrc24x
Is that the price for the 20mm thick 521 pad for my front calipers?
2000 degrees..wow. Impressive.
Old May 3, 2013 | 12:26 PM
Carbotech Adam
Supporting Vendor
Yes that's for the bigger pad.
If you would like to try them give me a call at 216-780-8825.
Old May 3, 2013 | 01:24 PM
LoneStarV's Avatar
LoneStarV
I looked on your site and all it showed was front brake rotors for a C4? No pics? Am i missing something?
Old May 3, 2013 | 03:57 PM
Carbotech Adam
Supporting Vendor
Yes, our website is s wealth of information, what can I help you with?
Old May 3, 2013 | 04:37 PM
LoneStarV's Avatar
LoneStarV
I was looking for options pricing and pictures of rotors for a 1988.
To Carbotech Performance Brakes
Old May 3, 2013 | 05:31 PM
Carbotech Adam
Supporting Vendor
We really do not sell rotors anymore sorry. What kind of pad are you looking for street, track or both? If you need rotors get some blank Centric rotors. Below is all corvette pads click the link.
http://ctbrakes.com/pads.asp?Make=Corvette
Old May 7, 2013 | 03:27 PM
Carbotech Adam
Supporting Vendor
Old May 7, 2013 | 03:30 PM
Carbotech Adam
Supporting Vendor
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
