increase loudness
Old Apr 11, 2013 | 04:38 PM
smorrisjmorris's Avatar
smorrisjmorris
Default increase loudness
Anyone know how i can increase the loudness of my exhaust system without changing the original pipes/muffler? THANKS in advance! Steve
Old Apr 11, 2013 | 04:52 PM
Daredevil95's Avatar
Daredevil95
There's not much you can really do without replacing exhaust. The only thing I could think of is taking the exhaust apart behind the exhaust manifold and punching out the catalytic converts.....the car will run better and sound a little more aggressive and I never had a problem with emissions but, every state is different. I have a 94 Vette.
I found this on google image search, I think this is what mine looked like when it was stock and easy to punch out.....I did this about 8 years ago so, my memory is foggy.
Old Apr 11, 2013 | 04:56 PM
John A. Marker's Avatar
John A. Marker
First the age old question that should always be in a post....WHAT YEAR CAR. It makes a difference for the muffler/pipes.
You COULD.....COULD......drill holes in the mufflers. BUT I REALLY WOULD NOT SUGGEST YOU DO THIS. It would make it louder, but you would promote the mufflers to rust out faster. Why not do it right and go with a better muffler.
Old Apr 11, 2013 | 04:59 PM
AirForceOne!'s Avatar
AirForceOne!
What year do you have? You don't have much of choice but to at least change your mufflers from the single outlet to a true double outlet.
Old Apr 11, 2013 | 07:22 PM
vetteoz's Avatar
vetteoz
If he wants LOUD , just install eliminators
http://forums.corvetteforum.com/c4-t...iminators.html
Old Apr 11, 2013 | 07:27 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
A cam!
Old Apr 11, 2013 | 08:06 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
You can replace the center resonator with straight pipes for a bit more growl. It won't be loud, but it's a start.
Old Apr 11, 2013 | 08:30 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by JrRifleCoach
A cam!
BINGO! W/o changing the exhaust system (and I can't imagine why the OP wouldn't simply change the exhaust), a cam is the most effective way that I know of, to increase the volume of your car's exhaust. Literally and audibly!
Old Apr 14, 2013 | 10:53 PM
smorrisjmorris
1994 coupe
Old Apr 15, 2013 | 12:31 AM
John A. Marker
The exhaust system on the 94 is pretty good. The only way to increase the loudness would be to go to different mufflers.
Old Apr 15, 2013 | 01:19 AM
tahoemedic's Avatar
tahoemedic
going to high flow cats makes a difference, or just eliminate the mufflers all-together but leave the resonator in...your ear drums will thank you, especially when cruising in overdrive/6th gear!
Old Apr 15, 2013 | 10:12 AM
c4cruiser's Avatar
c4cruiser
Any good muffler shop should charge something like $50 to remove the stock mufflers and replace them with exhaust pipe. You can even have them remove the factory tips and re-weld them on the pipes.
But as mentioned, leave the factory resonator in place, otherwise you will get a lot of interior resonance at cruise RPM (around 1200-1600 RPM).
Old Apr 15, 2013 | 01:05 PM
Kevin Woods's Avatar
Kevin Woods
Headers and a 'bigger' cam.
Originally Posted by c4cruiser
Any good muffler shop should charge something like $50 to remove the stock mufflers and replace them with exhaust pipe......
Or ^^^^^^^THIS^^^^^^^
KW
To increase loudness
