Torque sockets ?
Old Apr 14, 2013 | 11:09 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Torque sockets ?
Does anyone know where I can purchase a 19mm 100 ft. lb. torque socket ? I'm looking for the type sockets they use on air guns to install wheels w/o using a torque wrench.
Thanks,
Old Apr 14, 2013 | 11:18 AM
LoneStarV's Avatar
LoneStarV
http://www.nationaltoolwarehouse.com...ay-P49039.aspx
Old Apr 14, 2013 | 11:20 AM
c4cruiser's Avatar
c4cruiser
You mean torque sticks? Any of the professional tools companies will have them; Snap-On, Matco, and Cornwell.
Here's an interesting discussion about using torque-sticks. It's from a Honda forum and 4 years old, but the questions and comments posted there should apply. The discussion is about the accuracy of the torque value and the quality of the impact gun itself.
383vett's Avatar
383vett
Thanks,
Sears craftsman, snap on, harbor freight all make impact sockets.
Old Apr 14, 2013 | 11:39 AM
LoneStarV's Avatar
LoneStarV
I don't like them myself not to mention i won't use or let an impact anywhere near my lugs period. Started by hand,spun down and snugged with a spinner, torqued by hand with a torque wrench.
Old Apr 14, 2013 | 11:45 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Thank you.
Yes, torque sticks. Thanks guys, just what I was looking for.
Here's another dumb question. Can you use a torque stick manually on a ratchet or breaker bar OR must you use a 400 lb. air gun as the Honda post indicates?
Old Apr 14, 2013 | 05:15 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
NO! You can not use them manually. The way they work is that the stick is calibrated to twist a certain amount. When an intermittent load is applied the stick twists to absorb the excess torque and then returns to original state when the load is released. With an impact gun this happens very quickly with each pulse of the gun. That is also why they need to be used with a specific calibration to the impact gun. Both the applied torque from the gun and the speed of loading and unloading need to be matched to the torque stick.
It is a dynamic calibration tool. Manually it will twist and continue to turn the bolt while it is twisting more. If there is no dynamic movement, then it simply transfers all of the torque that is applied to it to the bolt. That will result in no control of torque except for the wrench (or torque wrench) that is driving it.
Old Apr 15, 2013 | 07:02 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks, QC, that's the information I needed.
To Torque sockets ?
