need help tip or big hammer ?
Old Apr 21, 2013 | 10:13 AM
pastamike's Avatar
pastamike
Default need help tip or big hammer ?
I'm removing the pump n opti, at the point of the crank pulley now. cant loosen the bolts because the dam thing keeps turning. how do i stop it from turning loosening the bolts, or I'm turning the wrong way??
help!!!!!!!!!!!
pastamike..
Old Apr 21, 2013 | 10:30 AM
hitmanpty's Avatar
hitmanpty
Hi my friend. I change my harmonic balancer abour a year ago.. first you have to stop the motor from turning.
the easy way for me was to stop the number one piston, by using a top dead center tool.
at the time I did not had this tool so i use the rope method. that consist, by introducing a rope into tho the number one cylinder into stop, at that point the engine is lock, and you can remove the bolt on the harmonick balancer.
top dead center tool look some like this
[IMG][/IMG]
Old Apr 21, 2013 | 10:33 AM
hitmanpty's Avatar
hitmanpty
check this video out. is all you need
Old Apr 21, 2013 | 12:32 PM
mtwoolford's Avatar
mtwoolford
Is it in gear ? are the rear wheels on the ground? is the parking brake set ? usually thats enough to lock up the drivetrain / engine and prevent the crankshaft from turning.
To need help tip or big hammer ?
