['88 Vette]Outer window sweeps-how to?
Old Apr 22, 2013 | 06:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default ['88 Vette]Outer window sweeps-how to?
I've dont the inner sweeps on the prior '88 so no issue there but had the outer ones done at purchase.
This '88 Vette needs both inner & outer sweeps and I am a bit confused as to how the outers attach and how to remove the old ones.
I see 5 "clips" along the new sweeps but not sure how these attach onto the door.
I don't want to mess up the sweep retainers in the door, so any insight as to how to replace them is greatly appreciated.
BTW, my GM Shop Manual and the www didn't provide much info on this job.
Old Apr 22, 2013 | 06:52 PM
don hall's Avatar
don hall
Anything here address your problem ?: ......
http://www.smokinvette.com/corvettef...p/t-45293.html
Old Apr 22, 2013 | 07:33 PM
65Z01's Avatar
65Z01
What a great detailed "how to" article; thanks so much seabright...
Old Apr 22, 2013 | 07:46 PM
don hall's Avatar
don hall
I remember '65Z01' from way-back, and you were helping hundreds of forum members solve their problems. I posed as 'Oldman' then,
but since passing age 80, that moniker is no longer relevant.
Old Apr 22, 2013 | 08:03 PM
65Z01's Avatar
65Z01
Well, I'm a few years behind you so I guess that moniker still fits me...
Old Apr 22, 2013 | 09:07 PM
joeld's Avatar
joeld
I replaced mine (89) a few weeks ago. That write- up pretty well covers it, just one tip I want to throw in. Be sure,very sure, that the holes in mldgs align with the holes in the door before you snap in the clips. Once those clips snap into the door, it's almost inpossible to adjust the mldg fore/aft.
Joel
Old Apr 22, 2013 | 11:32 PM
65Z01's Avatar
65Z01
Thanks for that tip Joel, I'll double check alignment...
BTW, for anyone else who might be doing the same job, here's the link to the "how-to" by Corvette magazine.
Old Apr 25, 2013 | 08:32 PM
65Z01's Avatar
65Z01
Well, as with many fine R&R projects this one isn't going exactly "by the book"...
The old sweep is out of the passenger door and I've made sure the new one aligns with the rivet holes.
The problem is that I can't get the clips to slip into the holes and engage. Is there a "trick" to this or perhaps I've buggered the clips??
Old Apr 25, 2013 | 08:44 PM
joeld's Avatar
joeld
I've read a few posts where some people have said they had problems also. Mine just snapped down with moderate pressure. Do these have the 3 fingers on the clip?
Joel
Old Apr 25, 2013 | 09:19 PM
65Z01's Avatar
65Z01
Yes, the clip style looks exactly the same as the OEMs.
I may have distorted the clips trying to press them into the slots in the PS door, so I tomorrow plan on freeing the front clip and removing the sweep. Then I can comapre clip conditions with those on the DS door sweep.
To ['88 Vette]Outer window sweeps-how to?
