1988 fuel pump
Old Apr 23, 2013 | 07:29 AM
1brian26's Avatar
1brian26
5th Gear
Default 1988 fuel pump
Does anybody make a fuel pump that might be a step up from stock that is a direct replacement that needs no modification?
Old Apr 23, 2013 | 07:40 AM
WW7's Avatar
WW7
Racetronics makes pumps that handle more volume, but unless you have done mods to your car that warrant higher fuel flow it's a waste of money..There's nothing wrong with stock AC Delco pumps , there are many Vettes with 25 year old and older stock pumps still working as they should.......WW
Old Apr 23, 2013 | 07:46 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
AC Delco pumps are about $50 on Ebay
Old Apr 23, 2013 | 08:25 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Any stock pump already pumps more than you need
Old Apr 23, 2013 | 08:27 AM
1brian26's Avatar
1brian26
5th Gear
Thanks for the info. I am assuming that's what is wrong because when I go on long drives it starts to seem like a starving for fuel. If I shut it off in and start up a few minutes later it's sputters then runs like it's starving. If I open the gas cap it sucks in air like it is sealed. I tried a new cap already.
Old Apr 23, 2013 | 08:42 AM
AGENT 86's Avatar
AGENT 86
You may want to have a look at your evap system.
Here is some info from my 86 service manual. Your year will be plumbed slightly different to canister.
http://members.shaw.ca/corvette86/Ev...l%20System.pdf
Old Apr 23, 2013 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Should point out that the line from tank to canister, may be plugged from rust.
Old Apr 23, 2013 | 09:16 AM
c4cruiser's Avatar
c4cruiser
Might be a good idea to replace the fuel filter too.
To 1988 fuel pump
