Bell sounds when lights are on
Old Apr 23, 2013 | 09:26 PM
fastercorvette's Avatar
fastercorvette
Default Bell sounds when lights are on
Hi - I have a 86 vert with an agravating problem. I am driving down the road, and turn on my lights, and the bell goes "ding ding ding" and on and on - forever, until I get tired of hearing it, and shut off the lights. Needless to say this limits my enjoyment of my car. Any ideas how to cut the wire to the bell? I don't want to actually fix it - unless it is a minor fix. If it entails tearing the dash apart, I am not really interested in fixing it - unless that is the only way. Thanks! PLEASE GO TO #20 FOR MY UPDATE ON THE PROBLEM.
Old Apr 23, 2013 | 10:34 PM
65GGvert's Avatar
65GGvert
If you wiggle the key in the ignition, does it stop for a while?
Old Apr 23, 2013 | 11:09 PM
fastercorvette
I will try that tomorrow. The car is at a shop. What does it mean if it does? Is the ignition switch bad? I have a brand new key, that I haven't used yet. Maybe I should try that, too?
Old Apr 24, 2013 | 01:20 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Not sure if a fuse is minor enough, but I'd check your Gauges Fuse.
Old Apr 24, 2013 | 05:11 AM
speedycat3's Avatar
speedycat3
Mine is a 93, and I have gotten the "ding ding ding" reminder when I leave the turn signals on for too long while driving straight. Maybe there is something wrong with your flasher.
Old Apr 24, 2013 | 07:34 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If the module doesn't know the ignition is on, headlight chime will go on and on.
From my 86 service manual
http://members.shaw.ca/agent86/Chimes.pdf
Old Apr 24, 2013 | 07:36 AM
fastercorvette
I checked all the 3-5 amp fuses, and they were ok. I figured (perhaps incorrectly) that a bell would not use a 10 amp or higher fuse. Was I wrong?
Old Apr 24, 2013 | 07:43 AM
65GGvert's Avatar
65GGvert
My thought was that maybe the ignition contacts are loose or dirty causing the module to read that the key was removed with the lights on. It seems like if your gauges fuse was blown, something else wouldn't work. Doesn't cost anything to try a different key.
Old Apr 24, 2013 | 07:46 AM
fastercorvette
I, unfortunately, don't know squat about modules, etc. Which module are you referring to? And what would be the fix? to change the module, I imagine, right? I had a 59 that in 64 I pulled the motor out of it, and changed the short block - by myself. But that car was not a technological nightmare like this 86 is!
Old Apr 24, 2013 | 08:05 AM
AGENT 86's Avatar
AGENT 86
The chime module.
Read the link, it explains how it works and how to diagnose.
Old Apr 24, 2013 | 08:10 AM
fastercorvette
The chime module.
I tried to read the link, but my computer wouldn't open it. Corvettes & computers & cooters - all a pain in the arsh.
Old Apr 24, 2013 | 08:12 AM
AGENT 86's Avatar
AGENT 86
It is a PDF file. Adobe PDF reader is free, if you dont have a PDF program.
Old Apr 24, 2013 | 09:37 AM
65GGvert's Avatar
65GGvert
I use pdf files daily and I can't get the link to work either. It starts to download and then locks up. I have to end task to exit.
Old Apr 24, 2013 | 09:40 AM
AGENT 86's Avatar
AGENT 86
Works fine when I try the link.
Old Apr 24, 2013 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Uploaded to my other site, hopefully it will work better.
http://dankai.shawwebspace.ca/asset/...155/chimes.pdf
Old Apr 24, 2013 | 09:57 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Both of your links worked just fine on my computer.
Old Apr 24, 2013 | 11:32 AM
fastercorvette
Yes, this one came out, ok. NOW if I could only print it.
To Bell sounds when lights are on
Old Apr 24, 2013 | 08:49 PM
fastercorvette
I took the vert to a shop that works on vettes. He pulled the front off the radio to locate the offending module. He also checked to make sure the lights under the hood weren't causing my problem. He told me the module was in a sealed box. Is there no easy way to cut the wires to this module, without screwing something else up? I don't want to trade one problem for another. Does anybody know? Do you KNOW somebody who knows? I talked to the vette mechanic at my local Chevy dealer. He has been working on vettes for 17 years and NEVER seen this issue before! Holy crap!!!
Old Apr 24, 2013 | 09:57 PM
AGENT 86's Avatar
AGENT 86
The chime circuit is pretty simple to diagnose where the problem is, when using the info in the link.
Did he use the info I gave you, or just dig in and bill you
Old Apr 24, 2013 | 10:03 PM
fastercorvette
He did not charge me for this problem. The problem I am having with the link is that I can't print it out. I tried for 1/2 hour - no luck. Is there NOBODY out there that has had this problem before? Is there NOBODY that can tell me how to disable the chime without screwing another system up? Being home before dark is a bummer! And who could listen to that chime for 1/2 hour or so? Not me!
