Didn't expect a major increase and you won't see one with just an X- pipe either on a stock car so its a waste. My car is a top down fair weather cruiser. I've had fast obnoxious cars and I'm past that now. Deleting the resonator gives a slightly more muscular sound without being annoying. That's about it. I have only had my car a short time but I've already learned that if you want to go fast cheaply then these cars are not the best choice....:-)
I'm doing the exact same as polo vert. Have the x pipe and just need the time. It isn't that much work, a few cuts and new welds and a nice throaty sound that won't make your head throb.
Because it was as much of a power improvement again plus significantly better ability to rev as when I swapped my intake to the Accel base, high flow runners and ported plenum. Of course now with the new engine it's a different story.
Did you have an X-Pipe made for you or did you use an aftermarket?
Does "blatantly obvious" make it more clear? If you're a car guy, you know when your car is running right and when it's not. When you make a change you either feel it or you don't. The exhaust change was an obvious improvement in throttle response, ability to rev and ability to accelerate. Looking at the difference between the horrid stock manifolds and the significantly better LT-1 manifolds what doubt is there?
I see.......................the old butt-o-meter.
Long tubes are probably worth 20 hp or so on average. Shorties I'd guess are half of that, so maybe 10 hp. Using that logic I would say a switch from the crappy L98 exhaust manifolds to the slightly less crappy LT1 manifolds might yield 5 or so HP.
I understand in CA you're limited with what you can do, but I'd still be hard-pressed to call 5 HP a "significant" gain. Just my .02
I just had my local shop cut out the resonator and weld in a pair of straight pipes. Works and sounds fine for what I wanted. Like I said, my car is stock so the x-pipe by itself wasn't really going to help me any. Cost me $50. If you have headers and aftermarket mufflers then the x-pipe is a fine choice to complete the package and maximize flow. For an otherwise stock car like mine, it won't help enough over straight pipe to be noticed. You'll just have a slightly lighter wallet.
Not really. I don't use the butt dyno which is why they made dynos in the first place.
If those are the only 2 options, sure. You can tell if it is running or not. Whether it is perfectly optimized or leaving 10HP behind, I don't think anyone is that good once we get upwards of a couple hundred HP.
I'm saying there are kids that feel a 20HP gain with a gear change too. Yes, it feels like it but it isn't. Numbers count. The rest is guesswork.
I'd believe it is better and can be seen on the datalogs but whether it can be felt, I don't know.
I have also known a guy that felt the better response and power with a 58mm Throttle Body. Too bad the dyno disagreed with him.
As far as I am concerned the butt-o-meter is so rough a measurement and so susceptible to the Placebo Effect, I consider it worthless for any fine measurements regardless of how much a "car guy" a person is or not.
20HP seems a little high unless the motor is tuned for it. I don't think you will see 20HP between a stock motor with LT headers and when you remove them.
Go pull a couple of plug wires off and tell me if you can tell that the cars not running right - or try to convince anyone here that you can't tell if it's lost power.
It's gonna flow better.
Well, if I put a 50 cal slug thru the engine, I can tell that it has lost power too. I am NOT talking of some extreme case like that any more than the plug wires. As I said, if it is not working, butt dyno can tell. When it is not operating at peak efficiency and you lose a few HP, it becomes much harder. When I had dirty injectors and one of them had a collapsed filter that restricted SOME, NOT ALL the flow, it was hard to tell. So, unless you gain 50HP on a 250HP motor, it is going to be very difficult to tell.
You know that but did you tell the ECM that? I put Accel Tri-Y headers from LPE on my 91 Firebird. No real noticable difference until Lingenfelter retuned the ECM. At that point, DIACOM picked up some difference. As I said, butt dyno is good for large increases. Smaller increases, hardly. So, do you think the car picked up 50HP or even close to that with just the manifolds? I think no.
Nope, I never said 50hp. Please note my previous post. Aside from that, maybe my butt is just better calibrated than yours.
I believe the OP started out by asking how to run true duals and then possibly a LT1 exhaust system on an 87. Somehow it has degenerated into the sensitivity of certain forum members asses.......
Fine. Tell us how much of a difference your butt can sense. I will admit that my butt is not as calibrated as yours and I can't sense little differences. That is why I pay someone to strap my car to a dyno to tell me power levels and I use datalogging software to find what the ECM is seeing and what is going on. So, tell us, on a 250HP car, how much difference can you sense? Or another way is how much power do you think your manifolds alone gave you? Again, I admit that I cannot consistently tell between a 250 and a 255HP car. Can you?
I did straight chambered pipes from cat and eliminated resonator and mufflers. I like the end result in improved sound, though I can not perceive any noticeable gain in power. This on a 93 LT1.
