Exhaust
Old Apr 24, 2013 | 12:05 AM
Pellno1's Avatar
Pellno1
Default Exhaust
HI
I'm having my 87 Vet engine rebuilt.would like to have two pipes all the way back instead of a crossover pipe just below the stock headers.Can't get headers,would like some info.how to run a passenger side pipe to the back end.
Thanks Jim
Old Apr 24, 2013 | 07:13 AM
jmgtp's Avatar
jmgtp
How about using the exhaust system from an LT1 car.
Old Apr 24, 2013 | 09:32 AM
Pellno1's Avatar
Pellno1
Can you explain the system and the car,which one is the LT1,this is new to me.
Old Apr 24, 2013 | 10:45 AM
jmgtp's Avatar
jmgtp
LT1 engines came in base model 92-96 cars. They use a true dual exhaust system and supposedly are fairly unrestrictive. They seem to be a popular choice for L98 owners to ‘upgrade’ from their factory system. I’m not certain but I believe it will require the full LT1 system including the 2 cat converters to bolt up to the L98 – also not sure if you can use the stock L98 exhaust manifolds or if the LT1 pieces will be necessary. I’m sure an L98 guy that’s swapped on the LT1 system can provide those details.
As a side note – you can find used LT1 systems for very little. I paid $75 last year for a complete system that I’m installing on my car to replace the too loud for me aftermarket exhaust.
Old Apr 24, 2013 | 10:47 AM
jmgtp's Avatar
jmgtp
here is a pic of an LT1 system that I stole from another thread
Old Apr 24, 2013 | 10:59 AM
mcm95403's Avatar
mcm95403
The inside of that resonator is restrictive as hell and negates the "true dual" idea. It also joins the exhaust inside so again it's not "true duals".
Aside from that, if you can't do headers you could replace the horrid stock headers with LT-1 manifolds like I did and get a significant increase. Technically, you have to keep all 3 cats for Federal smog compliance. Magnaflow is the only company that makes a decent catted y-pipe, but it currently has fit issues that they are working on.
How much power will you make? A single 3" can handle 325 hp effectively.
Old Apr 24, 2013 | 11:11 AM
jmgtp's Avatar
jmgtp
That's why I have an x-pipe to weld in where that resonator used to be
Old Apr 24, 2013 | 12:22 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Can you explain how the inside of the LT1/4 resonator is restrictive as hell and negates the true dual idea?
Old Apr 24, 2013 | 12:50 PM
mcm95403's Avatar
mcm95403
If you open one up you'll see how it's built. They're just like all of the GM muffler designs of that era. On the TPI Vettes they used "fake" dual outlets on the mufflers (except the 91's) to make it look like it flowed well. On the Chevy trucks of the time the 3" inlet necked down to 2 1/4", then went into a dead chamber. The only outlet from that 2 1/4" pipe were small louvers 1/4 of the way around the pipe, and then the flow reversed though 4 holes each the size of a dime.
The inside of that resonator is effectively one big chamber, although it's divided up into smaller chambers. Everything mixes in there - the pipes don't stay separate.
Aside from all that, a good single exhaust system will make more power than duals, but that's a whole nother conversation.
Old Apr 24, 2013 | 01:36 PM
ch@0s's Avatar
ch@0s
That Is a picture of My exhaust and I took a very long look at the LT1 system before I changed it over. The resonator as you will see here is not restrictive at all.
Old Apr 24, 2013 | 01:45 PM
jmgtp's Avatar
jmgtp
Good info. I'm removing my resonator for an x pipe primarily to gain some sound. I'll gladly accept some muffler back pressure if it means I can enjoy my car sans exhaust drone!
Old Apr 24, 2013 | 01:47 PM
ch@0s's Avatar
ch@0s
Here is a picture of the resonator cut out you can see it does neck down there might be some HP to gain but I wouldn't think much. I might go with an X pipe in the future but only because my exhaust is very quiet for me, I'm close to 400RWHP.
Old Apr 24, 2013 | 01:55 PM
James93LT1's Avatar
James93LT1
When I looked at an removed LT1/4 resonator, I was able to see right thru to the other end, on both sides. I can't see how that would be restrictive as hell.
Old Apr 24, 2013 | 02:59 PM
aklim's Avatar
aklim
Besides the rice factor, what is the point of true duals, especially without the X or H pipe? Why go thru the headaches if it is a DD? Getting good material and having it mandrel bent costs more effort than simply getting a good set of headers, a cat and cat back exhaust from what I can see unless you have a friend with a bender and some mad welding skills.
Old Apr 24, 2013 | 08:55 PM
TorchTarga94's Avatar
TorchTarga94
Yeah the resonator is nothing more than 2 perforated tubes in one can. Aside from it necking down a bit, it is not restrictive, nor does it join together anywhere. The stock LT1 Exhaust is a true dual system from the exhaust manifolds all the way back to the tips.
Old Apr 24, 2013 | 09:24 PM
TA's Avatar
TA
I remember your threads on your swap to the LT1 manifolds, but I can't recall your HP increase. Did you do dyno pulls or track numbers to show the improvement?
Old Apr 24, 2013 | 11:28 PM
mcm95403's Avatar
mcm95403
My trans wasn't in good enough shape to try to do dyno pulls with, sorry.
To Exhaust
Old Apr 24, 2013 | 11:35 PM
mcm95403's Avatar
mcm95403
That looks quite different from the one we cut off the car that the cat-back system we used to prototype the cat-back system for. Of course, that was 20 years ago, but I remember a very different looking resonator interior. Still, that one is a lot more restrictive than you might think since it lets the velocity drop to almost nothing.
Old Apr 25, 2013 | 12:58 AM
Polo Vert's Avatar
Polo Vert
I cut out my resonator on an otherwise stock car and I didn't notice any power increase but it is just a little louder when I stand on the throttle. No drone, turned out pretty much like I wanted it to.
Old Apr 25, 2013 | 01:18 AM
Aaron Keating's Avatar
Aaron Keating
If you aren't going to do headers, at least get an X pipe system. You can usually find em on ebay.
