Gear ration confirmation..........
Old Apr 24, 2013 | 04:10 PM
don hall's Avatar
don hall
Default Gear ratio confirmation..........
I read the following link regarding how gear ratio relates to speed and torque. Based on the explanations, I'm of the understanding that a vette with a 3:31 rear gear ratio will have less torque than a vette with a 2:59 ratio.... all other factors (HP, weight, etc.) being equal. Am I correct, or do I have it backwards?
http://wiki.answers.com/Q/How_does_g...eed_and_torque
Old Apr 24, 2013 | 07:20 PM
bjankuski's Avatar
bjankuski
You have it backwards.
Old Apr 24, 2013 | 07:46 PM
don hall's Avatar
don hall
Thank you..........
Old Apr 25, 2013 | 01:37 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.viperclub.org/howto/faqs/...-gear-swap.php
Old Apr 25, 2013 | 09:51 AM
don hall's Avatar
don hall
Good explanation...... thank you.
Old May 17, 2013 | 05:15 PM
jsiddall's Avatar
jsiddall
Just think about the math
These are important relationships:
power = torque x speed
acceleration = force / mass
In the case of an ideal car the force is (or more correctly is proportional to) torque and thus acceleration is also proportional to torque.
So if power is constant then when speed goes down (that's what the x:1 ratio means -- x turns of the input shaft per turn of the output shaft) torque goes up. So assuming a 1:1 transmission ratio an engine putting out 330 ft. lb at the crank going through a 3.31:1 ratio differential is going to be putting down 1,091 ft. lb. at the wheels (ideally half to each). That same engine torque with the 2.59:1 diff would work out to only 855 ft. lb at the wheels.
That's probably more than you wanted to know but helps explain, amongst other things, why torque is important.
To Gear ration confirmation..........
