C4 Factory Brake Swaps
I used to run a big block 4spd 1970 Cuda and with that I found out how to Install Huge calipers and Rotors off of a Fury with spindles from a 74-78 a body and certain caliper hat adapters off of another mopar I was able to mount on my 70 Ebody the biggest factory brake combo from later yrs onto my 70
So heres my Question First what factory parts are needed to install and run the bigger 13 inch 1996 rotor and calipers on a 1985 and is their bigger and better C5s or C6s that can be installed on the 1985
The brackets for the early C4 to C5 are less complicated than the 88+ year models to C5. I've never seen it mentioned but a base C6 front caliper might share the same adapter. MIGHT! Don't know!!
This might be an interesting read regarding an '84 but it covers your needs also.
http://members.shaw.ca/corvette.84/C5brakes.html
What I want to do is like my old Mopar Swap out Everything Factory. The key to my 70 E-body Mopar was the 1976 A-body Spindle Assy
I bet its there. Some spindle assy. Ive got to check on ball jiont interchangability that might give me a clue. Some newer swap out with a spindle assy from something newer
If the C5 or C6 Spindle Knuckle pops in Im good.
Got to find out what spindles interchange or maybe a spindle with upper and or lower control arms with a bigger Brake Booster and bigger master would be Sweet with a Adjustable portional valve with all Stainless Steel lines would be perfect
Do they bolt to the early C4 knuckle? That part, I don't know.
Or different ball jionts?
Or if the upper and lower control arms on the C5 or C6 Interchange with the C4?
I cant see why C5 or C6 upper and lower control arms couldnt be put on an older C4 with their complete spindle knuckles on the front atleast or swap out a spindle
Nice Real Nice and Cheep
http://www.ebay.com/itm/1970-1981-CAMARO-FIREBIRD-C5-Corvette-13-Disc-Brake-Kit-Tall-Spindles-/230966712250?pt=Vintage_Car_Truck_Parts_Accessories&hash=item35c6b057ba&vxp=mtr#ht_366wt_1159
http://www.ebay.com/itm/1964-1972-CHEVELLE-1967-1969-CAMARO-C5-Corvette-Disc-Brake-Spindles-/370802613955?pt=Vintage_Car_Truck_Parts_Accessories&hash=item56558edec3&vxp=mtr#ht_401wt_1159
JUST GOT TO FIND THE RIGHT ONE FOR THE 1985 VETTE OR A FACTORY ONE THAT WILL WORK
http://www.ebay.com/itm/97-04-Corvette-C5-FRONT-Spindle-Knuckle-Right-Passenger-/110997175712?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D15054%26meid%3D7219161086450328726%26pid%3D100005%26prg%3D1125%26rk%3D2%26sd%3D400396684189%26#ht_2564wt_1397
I bet I could bolt this up but Ill look to find a 1985 to compare
http://www.ebay.com/itm/85-CORVETTE-C4-LH-DRIVER-FRONT-SPINDLE-14084047-LH-/160956303173?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1985%7CModel%3ACorvette&hash=item2579be4745&vxp=mtr#ht_580wt_1159
Looks pretty damn close. Id bet this would work
85 Corvette C4 LH Driver Front Spindle 14084047 LH | eBay
Keep s posted!
[/URL][/IMG]
[/URL][/IMG]Here is the Answer Top Factory C5 Upper Control Arm
Lower Photo Factory Upper Control Arm 84-87
Anyone seeing what Im seeing
If they are the same distance apart or pretty close the end shaft can be installed on the 97-04 or its a cut and splice with the Mig
or this custom sweet 85 can be modified and I can do it or Ill call and maybe everyone here that wants one can also call SPC and ask them to graft a different nose on their custom upper control arm to just supply this for us. The one in the photo is only 225.00 If not Ive got guys that will do it for me and Ill have one soon
[/URL][/IMG]
As straight forward as the early C4 is to the C5 brakes and I believe also the C6 "base" brakes there's no need for an attempt to re-engineer the entire front end components and geometry for what you might like to do. The bracket is very simple, straight forward and if you wanted to clean it up it could be machined out of a single piece of material. That would be something that if you're capable of accomplishing you might consider.
Now I believe if you wanted to be really different and want "BIG" brakes the Viper caliper would be an easier package to adapt. The anchor method is much easier to accomplish a correct bracket for I believe.
Brembo might actually do a hardware package presently. I'd investigae maybe a Brembo or Wildwood set up. Maybe some others AP or whatever. The geometry of the front end is "problem free"!
I understand some of what you've referenced in your links to eBay but they're not actually "relative" to the task mentioned.
On the one hand, there is an opportunity here for you to be a pioneer in the C4 world...which is always cool when someone "plows the way" for the rest of us. But on the other hand, above, you shot down a simple one piece bracket b/c it's not stock. (?) Now you want to cut and weld suspension members to get it done?
Like I said above, keep us posted. I know that I am interested to see what you come up with.
The factory 97-04 entire swap isnt I reseached it a little more and the C5 Changes include a direct upper control arm frame mount
and the cammed the lower control arm for camber caster adjustments.
I think researching a 13 brake rotor factory Z51 set up with the trick SBC Upper control arm or going with the simple caliper hat bracket for the 12.8 C5 Set up would be just fine
Or just looking into swapping out the C4 1996 factory set up would be just fine with some good fresh air ducts pointed at the rotors
So Ive emailed them and Im waiting
I'm running C5 calipers and rotors, HP+ pads, and so far they've handled track days without issues.
Adaptor knuckles (spindles are the part that the wheel bearing rides on) is a neat idea, but I would buy the adaptor brackets for ~$150 before I bought $700 knuckles. Maybe others would have a different opinion though.
