Simple Question!!
Old Apr 26, 2013 | 04:45 PM
COPO's Avatar
COPO
Default Simple Question!!
Anyone be interested in a bolt in rear chunk to replace the Dana 44 that will handle at least 1000hp????? With a lot more options on gears and diffs
Old Apr 26, 2013 | 04:52 PM
93 ragtop's Avatar
93 ragtop
Yes. But are you doing anything with the axles, etc. or just the batwing and center section?
Old Apr 26, 2013 | 05:02 PM
esham's Avatar
esham
Still IRS?
Old Apr 26, 2013 | 06:41 PM
STEVEN13's Avatar
STEVEN13
Old Apr 26, 2013 | 10:22 PM
COPO's Avatar
COPO
Yes....keep it IRS. We be just the chunk from yoke to yoke with internals. Use your batwing. Bolt In!!
Inland empire rates their halfs shafts at 800hp. Carbon fiber at 1000hp. Driveshaft shop will be the same.
That leaves the outer stub axle...which can be made just like the yokes.
Old Apr 26, 2013 | 11:07 PM
Widebody's Avatar
Widebody
Default Chunk
Now you're talking!!! Have CF halfshafts and billet stub axles now. So what are we talking $$$$. Talk dirty to me!!!
Old Apr 26, 2013 | 11:19 PM
WVZR-1's Avatar
WVZR-1
Interesting but you're comment is somewhat in "circles" If it's bolt in there can't be more options of gears and diffs (your terms). There can likely only be a single ring/pinion style (different ratios, yes) and diffs (your term) the same would apply a single style (different locking tecnology, yes). A rear "chunk" - sure!
Interest - there's always interest but it's going to take a little more technically inspired "sales pitch" to generate serious interest I'd think.
Old Apr 27, 2013 | 07:31 AM
C409's Avatar
C409
.......... I'd be interested ... depending on price ....... whose gear sets does it use and is a spool available ? ........
Old Apr 29, 2013 | 10:04 PM
COPO's Avatar
COPO
Originally Posted by WVZR-1
Interesting but you're comment is somewhat in "circles" If it's bo in there can't be more options of gears and diffs (your terms). There can likely only be a single ring/pinion style (different ratios, yes) and diffs (your term) the same would apply a single style (different locking tecnology, yes). A rear "chunk" - sure!
When you go through about a 100 gear sets a yr...you realize how hard it is to find them. We will call it a replacement rear chunk.
As for a sales pitch...it will sell itself. I'm just throwing it out there for the C4 crowd.
And yes spools will be available along with 6.14 gears or ring and pinion
Old Apr 30, 2013 | 02:22 AM
yedister's Avatar
yedister
You have covered the drive and half shafts, center section and gears, what about the U-Joints?
How about the Dana 36?
Old Apr 30, 2013 | 02:36 AM
WVZR-1's Avatar
WVZR-1
This is what 9" "light weight" form factor or 8.8" just what form factor is the attempt to base it upon? It's based upon something that is considered "production" just interested in what!
Old Apr 30, 2013 | 12:56 PM
COPO's Avatar
COPO
Still have a lot to do but its a start
Old May 2, 2013 | 06:18 AM
93 ragtop's Avatar
93 ragtop
I look forward to seeing more about this!!!
Old May 2, 2013 | 07:06 AM
C409's Avatar
C409
..... Just wondering why you are so negative towards Dana 44 alternatives ? ..... New D44 stuff your biz ? ..........
Old May 2, 2013 | 11:30 AM
WVZR-1's Avatar
WVZR-1
I made NO NEGATIVE COMMENTS. I don't understand the basis for the "negative" that you imply. You've an attitude because of the doubt I raised regarding the D36 cover with "fabricated" adapter affair you "hustled"?
I've some D44-HD stuff but I wouldn't consider it the biz?
I essentially asked the platform it was maybe based on. You asked the same questions!
Old May 2, 2013 | 02:46 PM
ch@0s's Avatar
ch@0s
Old May 2, 2013 | 03:09 PM
STL94LT1's Avatar
STL94LT1
To Simple Question!!
Old May 2, 2013 | 10:18 PM
COPO's Avatar
COPO
Haven't saw a u joint break in a while. Doesn't mean they don't, newer the better. 44 has a different flange pattern. Will have to have a 44 cover.
Old May 2, 2013 | 11:20 PM
fc_soldier's Avatar
fc_soldier
Im in.... soon it will come down to straight axle for me. I rather stay IRS.
Old May 3, 2013 | 01:17 PM
93 ragtop's Avatar
93 ragtop
If you don't mind me asking, is that based on using 8.8 gears and posi unit or maybe 12 bolt?
