Magical Starter Problems
Old Apr 29, 2013 | 06:20 PM
nbanwart's Avatar
nbanwart
Default Magical Starter Problems
So i'm on my last stretch of CFI to carb conversion and now for some reason the barely used mini starter won't spin. I pulled the engine and replaced some of the old worn out wires with new ones (all in the correct positions). I have 12v on the solonoid in the right spot and the ignition is hooked up correctly but the starter won't start. It just clicks once and unclicks when I let go of the key. Any ideas? Brand new starter, was working before I replaced the wiring.
Old Apr 29, 2013 | 09:43 PM
Square's Avatar
Square
First thing I would do is pull the starter and have it tested.
Old Apr 30, 2013 | 03:03 AM
stormy69's Avatar
stormy69
unless the motor is locked suddenly, the starter has. i have bought new starters that were bad... exactly which starter do you have??
Old Apr 30, 2013 | 10:17 AM
don hall's Avatar
don hall
Originally Posted by nbanwart
..... I have 12v on the solenoid.... i
Maybe some info in this thread will help:
http://www.corvetteactioncenter.com/...hind-dash.html
Old Apr 30, 2013 | 12:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That thread is addressing the primary starting circuit (key to starter, so to speak). The OP has confirmed 12v at the starter solenoid and has solenoid clicking, which means that the entire primary starting circuit is working when he turns the key. His problem is either:
1. No power to the starter from the battery CABLE
2. Starter is toast.
I would test the starter by connecting a jumper cable (hooked to a battery) to the big lug on the starter. If you make good connections and the starter does nothing...it's bad.
Old Apr 30, 2013 | 03:15 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have seen this when there is a real poor connection at battery, worth a look.
Old Apr 30, 2013 | 03:49 PM
don hall's Avatar
don hall
Good point! With a poor/loose connection, you might still read 12V at the solenoid, but very low, or no, amperage will flow to the starter.
Old Apr 30, 2013 | 04:48 PM
TJM's Avatar
TJM
Redo the install after checking the starter. Be sure to be sure to get the shimming right.
Starters hate me... Had this , and other problems.
Ours had the tang from the solenoid crack... don't know how [ suspect 16 yo dropped it ?? he denied it] .. but it was cracked did.
DC does not like any gaps.. and it got worse after a little melting..
Have three broken cheap mini starters. That one, one that cracked the Al. clocking block when torqued, and the lasts that had the engaging arm break...?
Bought a NAPA High Torque model for a 1971 LT1/big block... no issues. A little heavy thought?
Old Apr 30, 2013 | 10:41 PM
nbanwart's Avatar
nbanwart
Definitely have some good connections throughout the system. Only weird thing is that solenoid wire goes from a 1/4" wire to like 14 gauge or something around 1/8" thick, but even if I put 12v from the battery to starter cable on the solenoid it still does the same thing. I put 12v on the other post of the starter which should turn it over it didn't, so I think the starter is done for. I'm gonna get the battery and starter tested tomorrow though.
Old Apr 30, 2013 | 11:59 PM
cudamax's Avatar
cudamax
Turn the headlights on and turn the key and try and start the motor. If the headlights dim Batery conection problem like maybe the neg terminal. If the headlights stay strong and dont dim at all get under by the starter and jump it with a screw driver from the batery hot wire on the starter to the small wire on the starter sol. It should crank by jumping the starter sol. Dont think the starter is bad I bet u have a connection problem. Maybe the neg terminal that u dissconected or the conections to the sol and this is all asuming u did not over tighten the small nut on the sol and cracked it
Old May 1, 2013 | 12:29 AM
stormy69's Avatar
stormy69
you never said if you were running a stock style starter, if so go here, last post first....
http://forums.corvetteforum.com/c4-g...-interest.html
you will see the power flow once you take it apart...
Old May 1, 2013 | 12:51 AM
vetteoz's Avatar
vetteoz
That would be the definitive test.
If applying 12V as noted above assuming you have full batt power and a good ground /Neg available through clean , tight connections direct
to the starter itself ( bypassing the solenoid ) has no effect then high likely the stater is shot.
No further testing needed
Old May 1, 2013 | 01:01 AM
cudamax's Avatar
cudamax
No. No No The starter needs 12 volts to the starter and then 12 volts to the sol to engage the sol to get it spinning or crank the motor.
Thats why I told u to get a screw driver and touch the 12 volt hot battery connection at the starter and touch the small screw on the sol. Dude
Jump the sol to spin the motor and only if u didnt crack the sol from over tightening the sol little screw.
stormy69's Avatar
stormy69
i agree and dont mean to question his abilities but starter post is generic enough that he could think that the solenoid post is also the starter post. I assume he does since he stated he got the same results. There would be no identical clicking sound from the starter post side of the solenoid...
Old May 1, 2013 | 01:18 AM
cudamax's Avatar
cudamax
Go on youtube and what videos on how to jump a starter
Old May 2, 2013 | 08:59 PM
nbanwart's Avatar
nbanwart
Just finished removing the starter to test it. The starter 'pops out' when I put 12v to both the solenoid posts but does not spin. However the starter spins when I give it 12v. Is there anyway to repair the solenoid? I put my old starter back in and it works, just afraid of the horrendous heat soak that starter gets.
Old May 2, 2013 | 09:17 PM
stormy69's Avatar
stormy69
So, go to the link i already posted and you can fix this for >$15...
Old May 2, 2013 | 11:08 PM
cudamax's Avatar
cudamax
buy just a sol and put it in. Those r cheep
Old May 2, 2013 | 11:40 PM
mako41's Avatar
mako41
This is a very easy and cheap repair that has been covered on this forum many times;
http://forums.corvetteforum.com/c4-t...with-pics.html
To Magical Starter Problems
