96 cuts out while driving
Old Apr 29, 2013 | 10:52 PM
brettalewis1's Avatar
brettalewis1
6th Gear
Default 96 cuts out while driving
Happens long after its warmed up, jerks and cuts out like it wants to die...slow and at hwy speeds, any experience with this symptom anyone?
Old Apr 30, 2013 | 01:33 AM
LouisvilleLT4's Avatar
LouisvilleLT4
I had this happen when my coolant temp sensor's connector melted against the water pump. When watching the coolant temp readout, the number would go crazy every time the car bucked. The car was rapidly switching its hypothesis from "engine temp is below freezing" to "engine temp is warmed up". One of the few problems the car had that I wasn't the root cause of.
This is hardly likely though, there's a thousand things to be ruled out using various measurements.
Old Apr 30, 2013 | 11:21 AM
lt4obsesses's Avatar
lt4obsesses
Does it cold start fine?
When warm, will it start right back up after shut down?
When symptom present, does it idle? Smooth? Rough?
Old Apr 30, 2013 | 11:25 AM
brettalewis1
6th Gear
Yes it's cold starts fine and runs smooth as glass idle or otherwise, it does sound like the battery is weal tho, especially after warmed up
Old Apr 30, 2013 | 11:32 AM
lt4obsesses
So when the car is warm, does it idle smooth?
Also, when warm, does it restart smooth?
Does it only misfire while moving at speed?
Is the misfire more upon accleration, or when you give it gas?
Old May 1, 2013 | 12:14 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default Icm?
Might it be the ICM (Ignition Control (Coil) module)?
Likely the ICM is screwed to a heat sink which is bolted to the passenger side head front side.
If loose and/or the heat sink paste has degraded or the ICM has gone bad, it might produce the symptome your getting.
FYI, Autozone has a tester for the ICMs.
On our 94, it just 'went', and the car wouldn't start, but after installing a new one, performance was improved and a 2k rpm hessistation went away.
BTW, only use ACDelco, have read others having problems with other brands. Radio shack sells heat sink paste which MUST be used (NOT the same as 'dielectric grease').
Old May 1, 2013 | 12:24 AM
lt4obsesses
I'm thinking ICM as well.
However, I had a some instances of this behavior for about a month or so prior to my fuel pump going out completely. This after replacing coil and icm. But mine would be more random events. No issues since the new pump went in.
But yes, first instinct tells me ICM.
To 96 cuts out while driving
