Wierd Starting Problem?
Old May 5, 2013 | 05:45 PM
AirForceOne!'s Avatar
AirForceOne!
Default Wierd Starting Problem?
The last 2 mornings in a row, my 90 didn't want to start (crank over) right away till about 3 or 4 tries. I leave the battery tender on it when not in use, so I know the battery is charged.
Had the battery(1 year old), alternator and stater checked at Napa Auto Parts and everything checked out good.
What could be causing this? Starter Solenoid or relay?
After I initially get it started, it starts everytime!
Old May 5, 2013 | 06:03 PM
don hall's Avatar
don hall
Battery could be charged, but the cable end to the starter could be corroded. Remove the positive cable from the batt, clean, if necessary, and tighten firmly. May not solve your problem, but you have eliminated a fault source.
If cleaning the cable end doesn't solve the problem, continue down the positive cable, and clean the terminal at the solenoid.
If that doesn't fix the problem, jump the solenoid to the starter. If jumping starts the motor, the solenoid could be your problem.
Old May 5, 2013 | 07:26 PM
AirForceOne!
Thanks, I'll try that tomorrow!
How hard is the starter to get to? There's not much room underneath!
Old May 5, 2013 | 07:34 PM
don hall's Avatar
don hall
Maybe beg, borrow, or steal a floor jack and jack stands.
Starter is readily accessible.
Some reading material that may help: http://forums.corvetteforum.com/c4-g...ter-relay.html
Old May 5, 2013 | 08:12 PM
AirForceOne!
I'll try the positive cable first.
Augh, if I have to jack it up, I'll take it to my vette mechanic at the "stealer ship"! I'm getting too old to crawl under cars!
Old May 5, 2013 | 08:19 PM
don hall's Avatar
don hall
I understand 'old'....... I'm 81...... jacking up the '92 to replace
O2 sensors next week.
Old May 5, 2013 | 08:31 PM
AirForceOne!
More power too ya, I'll pay someone to crawl under there!
Old May 5, 2013 | 09:21 PM
don hall's Avatar
don hall
....I'll pay someone to crawl under there!
Let us know what the tech discovers......
Old May 6, 2013 | 07:35 PM
AirForceOne!
Well I didn't have to take her in this morning, she cranked right up!
I did still take off the battery cables and cleaned them both, the positive was a little dirty, but not bad.
I did notice the dimmer switch was in the full up position, maybe that is what drained the battery?
The only other thing I did different was install the rear hatch vent, but the lights were all off when I closed it?
Anyway, she runs fine now!
Old May 6, 2013 | 07:48 PM
don hall's Avatar
don hall
Good fix, and you didn't have to crawl under the vette.
Yes, if the dimmer switch was in the 'up' position, there will be an extended battery drain (10 minutes), but the lights are turned off after that period of time.
Thanks for reporting back with results.
Old May 6, 2013 | 08:12 PM
AirForceOne!
I wouldn't think 10 min would drain the battery to the point it wouldn't start would it? I guess every time I opened the door another 10 minutes on hugh!
I'm not sure what the cause was, but I'm glad she works again!
Old May 6, 2013 | 08:36 PM
don hall's Avatar
don hall
I wouldn't think 10 min would drain the battery to the point it wouldn't start would it? I guess every time I opened the door another 10 minutes on high
You are correct...... 10 minutes will not drain the battery, especially if you use a tender. The tender should replenish any lost charge within a few minutes. Even without a tender, the alternator would charge the batt the next time you drive. There is no accumulation of amp draw between charges.
Since the batt is only 1 year old, and always on a tender, there should not be any drop in charge. I'm aware you had it tested.
If you experience battery failure in the future while still using a tender, there is an electrical problem.... more likely a faulty batt,
or an amp draw exceeding the charging rate of the tender.
It is possible that a 'poor' batt cable connection would not carry the charge from the tender, consequently, you experienced a failed batt. The same would affect the alternator charge. The batt may not have been receiving a complete recharge.
Normally, a batt test includes a 'load' test. If that wasn't performed, it should be the next time.
It would be interesting to learn what the digital volt reading you see on start-up (14.5V+ normal) for about 5+ minutes.
Old May 6, 2013 | 08:59 PM
AirForceOne!
Yes, they did a load test at Napa Auto Parts. On start up the volts wer 14.7. He had me turn on the head lights, heater ect and the volts were at 12.7 I think? Any way he said everything was fine!
Old May 6, 2013 | 09:10 PM
don hall's Avatar
don hall
The 12.7V reading concerns me. That appears to be just a batt reading, and the alternator is not contributing. It may be OK, but even with all electrics on, the alternator should still provide a charge over and above a batt reading....... I would expect to see a charge rate of about 13.5V with all electrics on.
Was the alternator removed and load tested, also?
Old May 6, 2013 | 09:49 PM
AirForceOne!
I'm not exactly sure what the numbers were, it may have been higher. All he said is that they all tested good, the battery, starter and alternator.
Old May 6, 2013 | 11:07 PM
leesvet's Avatar
leesvet
A corroded pos cable will cause all this...
you cannot see inside it, and it may work fine for weeks at a time until that day where it just will not carry the amperage to throw the solenoid.
A dirty/dying solenoid will also do all this...the solenoid contacts get burnt, then as you turn the key the voltage might flow but the contacts are too dirty to conduct. new solenoid or at least a disassembly to clean and inspect.
For a few minutes after start up your gauge should show at least 14.0 volts...at least that. Then after the initial drain has been replaced, it should settle in the 13s depending on what accessories are running and rpm.
Old May 7, 2013 | 12:52 AM
cudamax's Avatar
cudamax
What a Battery Tender? U SHOULDNT BE CHARGING THIS.
u could of overcharged ur battery water out. If u ve been doing this for a while.
Check ur battery water level
To Wierd Starting Problem?
Old May 7, 2013 | 01:23 AM
Cliff Harris's Avatar
Cliff Harris
A Battery Tender is a special type of battery charger. It has a microcontroller inside that continually monitors the condition of the battery and makes sure it isn't overcharged. If you don't drive the car for fairly long periods of time (like more than a month) you definitely NEED one of these. They are by far the best and are WAY better than a so-called "trickle charger".
How do you check the water level of a sealed battery? Virtually 100% of the batteries made today are sealed and shouldn't be opened (if you can even do it).
Old May 7, 2013 | 09:24 AM
AirForceOne!
I only use my battery tender when I work my 4 12's, then I leave it off when I 'm off for 4 days. The security system is always draining your battery a little bit when you don't drive it.
Like Cliff said it's fully automatic and won't hurt your battery, just keeps it fully charged at all times.
Old May 7, 2013 | 09:53 AM
cudamax's Avatar
cudamax
Never heard of that before Anyways here is a video of topping off ur sealed battery if u dont mind staring at a blonds butt bening over an engine compartment
www.youtube.com/watch?v=3PLSztkJGqE
