94 LT1 battery light & check engine light on
94 LT1 won't start
I replaced the battery with a yellow top optima; had a red top before. Cleaned both positive & negative battery terminals. Cleaned & checked wires coming & going to the fuses in the engine compartment & alternator. Replaced alternator & ignition control module also had the coil checked it is fine. I checked for spark on plugs & wires No Spark. After everything I've checked or replaced the Vette still won't start; it tries but no Cigar. The battery light & check engine light remain on. Please Help.
Any wisdom will be greatly appreciated.....Thank You.
Would like to know what problem occurred first and what you focus is on. I assume it is the no start problem. The alternator will not affect the spark. Did you check for spark off the coil and not just the plugs. Can you check your fuel pressure or injector pulses at the injectors?
You will get a battery light and check engine light if the engine is not running......
Here are some items to check in no particular order since there is limited information so far.
Fuses: fuse 25, coil: fuse 14 fuel pump: fuse 22 & 23 injector voltage: fuse 33 PCM.
It would be nice to know if there is 4 VAC driving the ICM from the PCM.
If you have a check engine light on before you could not get it started, then you should check for codes and see what codes have triggered the light.
Just wondering, did you replace the battery and alternator in hopes of getting the engine stared?
I'm trying to give as much info as I can sorry if I've confused you.
the car was driving fine; then it started stumbling & shifting very hard @ 3grand. Then the service asr light & check engine light came on so I parked her. Then it wouldn't start up anymore; so I checked for code's. It gave me code H64 = RF O2 Sensor Lean; I cleared it. Yes I checked the coil for spark there's non I had the coil checked out at the auto parts store and they said it was fine. Yes I did replace the battery, alternator, and the ignition control module in hopes that it would start.
I checked the fuse you told me with a test light and there fine but these didn't light up on both sides............
1 a/c, 5 htd Mir, 7 horn, 9 crank air bag, 10 crank p/n clutch, 11, rh illum
12 lh illum, 13 cnsl illum. I don't know if this has anything to do with it.
Hope this info helps. Thank you.
(If there is no injector drive, then the opti may be bad.)
I would assume then that the drive for the ICM is being developed. In that case I would at least get the ICM checked or replaced with a GM part.
Do you have a DVM or the FSM manuals?
I re-read the post and see you have already repalced the ICM. You might then have a opti problem but would not run with it quite yet. There is still lots of other things to check.
I'll go to an auto parts and get a noid light. I've been looking for my manual can't find it; so I'll have to see if they have one there. I'll check this out and get back to you. One more question is there a specific way of checking the spark off the opti?
I know I've been MIA for awhile sorry I was in and out of the hospital. Feeling better though. Anyways I found my repair manual. Then while I was at the hospital a friend of a friend who works for Chevy down here. Took a look at it and said the opti got wet and fouled out. I ordered the msd with the adjustable timing screw. Can you give me any feed back on it?
