Just bought this 87, it wanders
Old May 6, 2013 | 11:41 PM
87-red-convertible's Avatar
87-red-convertible
7th Gear
Default Just bought this 87, it wanders
Just got this nice 87 Convertible. It runs good but it seems to wander.
At slow speeds it seems the steering wheel does its own thing
and at high speeds is seems unsafe.
Had a prepurchase inspection done and it was very basic ( no alignment test or anything) but they took it on a low speed drive.
Only real thing they mentioned was the tires. Rear at 60% front at
15% . So the fronts need to be replaced but can that really cause
The steering to be off and wandering ?
Old May 7, 2013 | 12:47 AM
cudamax's Avatar
cudamax
Put a floor jack right under the lower control arm and lift the wheel up off the ground. That way all the weight off the car is on it.
Then grab the wheel at 12 oclock and 6 oclock and with ur hands forcably try and move the wheelin and out and at the same time have someone else look at the upper and lower ball joints.
Any movement at all is real bad and dont drive unless u replace
Then grab the wheel at 3oclock and 9 oclock and forceably move it back and forth.
Now u will be looking at the tie-rod ends and the rest on all the front end components
See whats bad and replace them
Good luck
Old May 7, 2013 | 07:45 AM
WW7's Avatar
WW7
To answer your question...Yes , the tires could be causing it to wonder..If your roads are rutted, this can also make the problem worse.. When my tires get down to there "end of life" I notice a big difference with my 89...Put on new tires, get a 4 wheel alignment, and I'll bet the problem goes away, as long as there are no worn parts in the front end... Most shops will check the front end for worn parts before doing an alignment, they will let you know if you need anything replaced....WW
Old May 7, 2013 | 08:39 AM
LT4 F45's Avatar
LT4 F45
Check the tires pressure first, it should be at or around 35PSI if lower than that the car il be soft and waving on the road...
Old May 7, 2013 | 08:45 AM
leesvet's Avatar
leesvet
the fact the the fronts are shot tells you THERE IS a front end problem....either wear or simple need for alignment.
Old May 7, 2013 | 03:51 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Like LT4 said, check your pressure first. Could be a few things wrong like rod ends, ball joints or alignment.
Old May 7, 2013 | 04:06 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Tires do wear out without front end problems
Old May 7, 2013 | 04:08 PM
Cruisinfanatic
Absolutely the fronts could cause all of the problem. Get them replaced (all 4 is better) and you will be amazed
Old May 7, 2013 | 04:26 PM
JackDidley's Avatar
JackDidley
4 new tires and a 4 wheel alignment and you will think you have a new car.
Old May 8, 2013 | 05:41 AM
gerardvg's Avatar
gerardvg
Right on! 35-38 psi is the sweet spot, lower tire pressure makes the car wander with uneven road surfaces.
Get some new tires a wheel alignment and the suspension checked again, adding more positive caster helps center the wheel and give more stable high speed feel.
Old May 8, 2013 | 08:31 AM
87-red-convertible
7th Gear
thank you all for your comments/ advice .
I have ordered 4 new tires and will get an alignment done and will post the results
Old May 8, 2013 | 10:52 AM
leesvet's Avatar
leesvet
Unlikely IMO when the rears are at 60% and the fronts are at 15% left...
Knowing this is a RWD car where the rears are getting grinding torque applied at every stop lite, unless he is driving a road course at high speed the fronts should be the set with the 60% left..not the rears.
When I drove daily and everything was "right"....I always trashed the rears first if I failed to rotate properly.
Thats been my experience on a C4...just my thoughts and experiences with tire wear.
Old May 8, 2013 | 11:01 AM
HattonC4's Avatar
HattonC4
5th Gear
Good luck
I agree but when you are checking tie rods you really need the tires on the ground and have someone shake the steering wheel back and forth. That way the tires will have resistance and you will see play (or feel it as I prefer) in the tie rods if there is any.
Old May 8, 2013 | 12:34 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
If its a good alignment shop they'll tell ya when you get the alignment if you have bad ball joints/tie rod end etc....
Old May 9, 2013 | 07:27 AM
AQUILA163's Avatar
AQUILA163
In 1988 the suspension geometry was changed to reduce scrub radius to 0. 84 to 87 corvettes chase the ruts more than 88 and newer because of this. I was a master tech at chevy when these cars were new and actually saw chevrolet buy 2 cars back for this. It's really not a problem, the cars just grab the road ruts a little more than others. My 07 Z4 was much worse. This car is 25 years old and tires may have been changed 2 at a time so nothing can be inferred from front to rear comparison. I would be much more suspicious on a corvette owner that says he never spun the rear tires. You need 4 new tires and an alignment anyway.
Old May 9, 2013 | 07:46 AM
lt4obsesses's Avatar
lt4obsesses
Good starting point. It really is amazing how these suspensions react to worn tires. As was said, when you get the alignment, you'll get a fair diagnosis on your suspension. If they don't offer the information when you pick it up, just ask about it.
Old May 9, 2013 | 08:09 AM
Cruisinfanatic
Means nothing since neither you or the OP knows the history of the car and how the tires were rotated and or replaced
The fronts could be older than the replaced rears. Nobody knows
To Just bought this 87, it wanders
Old May 10, 2013 | 07:58 AM
87-red-convertible
7th Gear
I have the tires but have run into another problem.
I CANNOT get to a Corvette specialist for a few weeks
and so I must have the tires put on at the local Chevy dealer. My question is, are these modern day Chevy dealer young punks going to know how to lift my 26 year old fibreglass beauty?
anybody out there experience this (almost mon existent jacking points)
Old May 10, 2013 | 09:23 AM
lt4obsesses
I'm sure you'll be fine. Now if you are at Walmart or something like that I might worry.
Old May 10, 2013 | 10:32 AM
79C3tnd's Avatar
79C3tnd
