C4 Idle and digital dash
Old 05-07-2013, 10:46 AM
beechwoodrick
3rd Gear
beechwoodrick's Avatar
Default C4 Idle and digital dash
Have a garage kept 90 C4 that was on a 3 day trip parked in constant rain. Went to start and no digital dash and would not idle below about 2000 rpm. Drove home anyway and dash light up and it smoothed out. After sitting and now only the fuel gauge works and speed reads zero...won't idle below about 1200. Service engine light on. Any ideas?
Old 05-07-2013, 11:40 AM
stevie1dr
stevie1dr's Avatar
Did you check for any codes? Idle may be the TPS A 21 will indicate a bad TPS.
Old 05-07-2013, 02:28 PM
beechwoodrick
3rd Gear
Default Codes
Should have taken the time to figure out how to pull codes....other vehicles either are OBD2 compatible or before the code periods. Easier than I thought. Got a bunch that I need to look up. C41 H-32, 34, 36, 38 and H41
Old 05-07-2013, 02:33 PM
leesvet
leesvet's Avatar
go thru the grounds and the jumper pole power source leads. They're just dirty or loose.
Old 05-07-2013, 02:38 PM
beechwoodrick
3rd Gear
leesvet....really appreciate the comment...what do you mean by the jumper pole power source leads?
To C4 Idle and digital dash
Quick Reply: C4 Idle and digital dash
