car wont start
Old Jun 21, 2002 | 10:54 PM
85autoxr's Avatar
85autoxr
Default car wont start
had battery tested it is good. car will just click then dash goes out .volts on dash read 10.7.can someone point me in the right direction?also noticed a problem with dash lights before,twice the dash went blank,then came back on. the other problem was the display on the dash went haywire, it was like a kaleidescope. please help first time vette owner. :mad :mad :mad
Old Jun 21, 2002 | 11:09 PM
Bluevette85's Avatar
Bluevette85
Default Re: car wont start (85autoxr)
I'd say it either the altenator or battery. How could the battery check out okay and only have 10 volts? Did it drain because the altenator isn't charging it?
Old Jun 22, 2002 | 12:09 AM
jfb's Avatar
jfb
You have a corroded battery terminal connection. Remove the battery cables, ground first, then get a stiff brush and/or steel wool and scrub the cable lugs until they are clean and bright. Clean the battery terminals also and replace , ground last. I also recommend you go to a parts place and buy 2 large brass battery terminal bolts (5/8 hex) and throw the GM 5/16 wimpies out with the trash.
Charge your battery up with a charger.
[Modified by jfb, 10:10 PM 6/21/2002]
To car wont start
