Vacuum lines
Old May 8, 2013 | 09:25 PM
jimmers's Avatar
jimmers
Default Vacuum lines
Does anyone know where to get those little plastic vaccum lines. Anyone replace them with something else? I'm pretty sure they are all for the emission stuff. A lot of mine are cracked and taped back together.
Old May 8, 2013 | 09:48 PM
rrt898's Avatar
rrt898
You can buy the lines at AutoZone or any other parts store. I replaced mine with normal rubber vac lines. It seems to work better for me. The high temps under the hood make the plastic lines very brittle over time.
Old May 8, 2013 | 09:58 PM
jimmers's Avatar
jimmers
I've tried 3 local part stores and none of them have any that small. They've all said to try the dealer.
Old May 8, 2013 | 11:06 PM
rrt898's Avatar
rrt898
I saw them at AutoZone, Advanced Auto Parts, Pep Boys. Try a franchise auto parts store. The lines are pretty cheap. I did buy mine at AutoZone but; never used them.
Old May 9, 2013 | 02:05 PM
jimmers's Avatar
jimmers
I've tried franchise stores, no luck here. Oh well.
Old May 9, 2013 | 03:21 PM
rick lambert's Avatar
rick lambert
I bought all from a local NAPA, hoses (plastic, and all new connections).
Old May 9, 2013 | 05:44 PM
rrt898's Avatar
rrt898
I guess if you want them that bad. You can order them online. Here is just one size but; AutoZone has all sizes and connectors.
http://www.autozone.com/autozone/acc...er=365573_0_0_
Good Luck
Old May 10, 2013 | 02:01 AM
Cliff Harris's Avatar
Cliff Harris
I believe the correct size is 3/32". AutoZone has them but they were cheaper at Pep Boys.
To Vacuum lines
