removing sun visor
Old May 9, 2013 | 12:48 PM
hitmanpty's Avatar
hitmanpty
Default removing sun visor
Sorry about the tittle . Is sun visor . Not fun
How do i remover the fun visor.? I get to the point where there is a spring assemble . I dont know How to remove .
[IMG][/IMG]
Old May 9, 2013 | 02:30 PM
speedycat3's Avatar
speedycat3
You have to remove the metal cap that holds the spring on to the sun visor shaft.
Kind of tricky.
What I did was use an adjustable painter pole, (short enough to fit within the bottom part of the sun visor shaft, and that allowed me to put ll th pessure I needed on the upper cap in order to get it to rotate and ome out. The upper part of the shaft has a bit of thread for the cap to cew in. You need to push down on the cap at the se time as you are trying to turn it.
If your new ones came with replacement caps, then don.t worry abot them getting messed up. you will need to hold the shaft from below in order to compress the sping and put the cap back on for reinstalation.
Old May 10, 2013 | 02:45 AM
Cliff Harris's Avatar
Cliff Harris
The sun visor shaft is not threaded on the early cars. The spring cap is held in place by a small clip that is pressed down over the shaft and fits in grooves in the shaft.
I pried the clip out with a wood chisel. It broke (fortunately I had a couple of spares):
Old May 10, 2013 | 10:16 AM
pcolt94's Avatar
pcolt94
I wanted to also remove the visor to do a custom repair on it. Never went to the effort of really trying to get it off. But in light of this information, I think I will just leave well enough alone.
I have already repaired a small ripped area on one of my visors. I think will do my repair work on the car even though it might be more difficult and not create additional problems for myself. It might not be as perfect but it will be a good job.
Old May 10, 2013 | 03:42 PM
hitmanpty's Avatar
hitmanpty
my car is and older vertion. so it not have thread
Iam guesing I have to buy new cap and clip. because the old ones will be damash
is this right
Old May 10, 2013 | 09:39 PM
Awolfa's Avatar
Awolfa
I just replaced bith of mine on my 93 vert. I had a threaded cap on the spring with a small nut on top of it. I removed the top nut, then used a small screwdriver to hold the cap while I rotated the visor 1/2 turn. Roatated the whole thing back then repinned for another 2/3 turn. It took awhile but it worked. I ordered all new parts for the replacement and used a small socket to drive the new cap down foar enough to start the new nut on the stem. Don't know if this will help any but worth a shot...
Good luck
Old May 11, 2013 | 12:55 AM
Cliff Harris
is this right
The cap will be OK. You will probably need a new clip. I think they are used in many places, so they should be easy to find. Here's a good picture:
Old May 11, 2013 | 03:06 AM
DinoBob's Avatar
DinoBob
Just did a full visor replacement last night. The new visors came with new retainers so I just gently worked at prying them with a screwdriver until they popped off. Getting them back on is no picnic either.
Old May 12, 2013 | 10:28 PM
hitmanpty's Avatar
hitmanpty
here is what I did.... clip btoke in the process. so now I have to get a clip. I think I can get down here.
[IMG][/IMG]
To removing sun visor
