Need Superram instal help.
Old Jun 22, 2002 | 01:08 AM
h rocks's Avatar
h rocks
Default Need Superram instal help.
Where does the MAP sensor get mounted? What method did you use to connenct the brake master.
Old Jun 22, 2002 | 01:11 AM
scorp508's Avatar
scorp508
The MAP sensor is mounted on the rear of the SR. There is a small screw hole and 3 large vacuum holes on the right-rear of it. The MAP sensor goes in the right-most vacuum hole, and the small screw hole is what you bolt it to.
The brake master requires you to get a 13" piece of 7/32" vacuum line. Connect the 90* brass vacuum fitting to the vacuum hold on the back-left of the SR pointing down, and connect that 13" piece of hose to it and the brake master.
Old Jun 22, 2002 | 01:36 AM
Corvette0096's Avatar
Corvette0096
Default Re: Need Superram instal help. (h rocks)
Its a fairly easy task took me 6 hours.. :lol:
Old Jun 22, 2002 | 01:50 AM
h rocks's Avatar
h rocks
Default Re: (scorp508)
Lemme get the MAP location correct first...
On the right rear, I believe that I have the three vac holes with the three small single barbed fittings, plus one more threaded hole above the three that apears to the same size as Ideas? thoughts? Doesn't appear that I've got any small bolt holes.
Lastly, it appears that my throttle cable is almost too long. Ideas?
Thanks.
Old Jun 22, 2002 | 01:59 AM
scorp508's Avatar
scorp508
Ok here is mine...
My leftmost one is my HVAC line, the middle is my fuel pressure regulator, the rightmost one is blocked off (I have no MAP on a MAF car.) Above and between the middle and right vacuum fitting you can see a single M6x12 screw installed. That is where you would bolt the MAP sensor bracket.
Old Jun 22, 2002 | 02:01 AM
scorp508's Avatar
scorp508
Thanks.
Auto or stick?
If auto, you need to lay your throttle valve cable for the tranny down BEFORE you bolt the plenum on. You lay it inside the runners between them and the plenum. I was able to use my stock throttle cable bracket on my stick car. The auto MAY require a different one. Some haven't.
Old Jun 22, 2002 | 02:40 AM
h rocks's Avatar
h rocks
Wait a minute...I forgot that you don't have a MAP sensor! But I do see that bolt in the hole above the three vacuum port holes. Mine is the same size as your lower three.
Old Jun 22, 2002 | 02:41 AM
h rocks's Avatar
h rocks
ZF
Old Jun 22, 2002 | 02:49 AM
DOCTOR J's Avatar
DOCTOR J
Here's a throttle cable pic:
http://temp.corvetteforum.net/c4/doc...superram_s.jpg
MAP is in front of the distrib - I used the bracket & bolt off the old plenum - had to bend it some, don't remember - maybe it had to be inverted? Don't have a close-up pic.
http://temp.corvetteforum.net/c4/doc...1-SRRt15Sm.jpg
http://temp.corvetteforum.net/c4/doc...-SRRtLo5Sm.jpg
HTH
Old Jun 22, 2002 | 05:36 AM
bill mcdonald's Avatar
bill mcdonald
Default Re: (h rocks)
H rocks. I have a 90 6 speed with the super ram.
I used the far right fitting for the Map sensor. the threaded hole abpve those 3 ports is for a bolt. I think someone opened that hole up to use it for an additional fitting on your plenum. That bolt is to hold the maps sensor bracket onto the superram. I had some trouble using the stock bracket and made my own out of sheet metal. It is just an L shaped bracket.
Also, I just ran my throttle cable over the plenum. I dont know if you are suppose to run it under it. I did not have any room because I ran all the injector wires under the plenum, and they were wrapped in heat sheild.
[Modified by bill mcdonald, 1:38 AM 6/22/2002]
Old Jun 22, 2002 | 10:38 AM
RocketSled's Avatar
RocketSled
Default Re: Need Superram instal help. (DOCTOR J)
THere's some FUNKY stuff goin on in those pictures! You're showing 1-2-4-6-8-7-?-? for a firing order? (As opposed to 1-8-4-3-6-5-7-2) And did they change the paint on the EGR tubing, or was that something you did?
Old Jun 22, 2002 | 01:04 PM
scorp508's Avatar
scorp508
:eek: Lets hope it was just for a picture plugging the wires in like that.
Old Jun 22, 2002 | 01:43 PM
HighHopes85's Avatar
HighHopes85
Default Re: Need Superram instal help. (RocketSled)
Yeah, really crazy--because you know that spark for the number 2 cylinder can only travel through a sparkplug wire labeled "2" ;) Kinda like battery voltage can only travel through a wire with red insulation :lol:
Gee whiz...if pics of a clean setup get this much :mad remind me never to post pics of mine. :p:
Old Jun 22, 2002 | 01:51 PM
scorp508's Avatar
scorp508
Default Re: Need Superram instal help. (HighHopes85)
Look at hte pic and follow where the wires go! he's right.
Old Jun 22, 2002 | 03:02 PM
HighHopes85
Default Re: Need Superram instal help. (scorp508)
Someone (Moroso?) used to sell a cap that rerouted the plug wires for clean installation...I think it was called a Correct-a-Cap but I can't find listings for it now. So I suppose the pics were either for mock-up or he has that style :)
Old Jun 22, 2002 | 03:59 PM
DOCTOR J's Avatar
DOCTOR J
Um, for many years an outfit called 'Crossfire' made the caps that I used on my Chebbie V-8's - you can see one here, if you are interested: http://yearwood.safeshopper.com/562/cat562.htm?13
Also, as HH points out, Moroso made the 'Maxi Cap' which was similar, and there were one or two others. I don't think any of them are available any more - old-style distribs aren't really the wave of the future.
BTW, if you look at an LT-1 engine, you will notice that even GM eventually learned how to bring the plug wires out on the same side of the engine where they are being used (without having to change the firing order). Wiring can do wonderful things like that.
HTH
[Modified by DOCTOR J, 4:40 PM 6/22/2002]
Old Jun 22, 2002 | 09:01 PM
RocketSled's Avatar
RocketSled
Aww heck, YOU know that, and _I_ know that...but whatabout the mechanic for the second owner? :jester
To Need Superram instal help.
Old Jun 22, 2002 | 09:14 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
I'm glad you asked this question h rocks, I was going to ask for the vacuum line pics that are posted here because I couldn't find them in my recent searchs.
How hard was it for you guys to screw in the brake vacuum fitting, mine almost seems like the fitting is too large for the hole and won't readily turn more than the first thread or so. I won't force it, just thought I'd ask before I proceed. (SR was purchased new)
I really don't want to use any gasket adhesive on the upper SR but some guys say to use it, are vacuum leaks that likely on the SR upper?
Old Jun 22, 2002 | 09:35 PM
scorp508's Avatar
scorp508
The brake booster fitting would turn in about 3 threads on mine by hand, and then required a wrench to turn it a couple more. Use some thread sealant and you should be fine with just a few threads turned in. Don't OVER tighten anything on it, they are tapered threads.
I used a very light coat of RTV on both sides of the runner lower and upper gaskest. I didn't use any on the TB or the lid gaskets.
Old Jun 22, 2002 | 09:44 PM
HighHopes85
RocketSled-Sorry for kinda getting OT here, but I guess you have to get a 5 quart jug of 5W30 Coastal oil thrown at you because--you sold a guys wife black insulated wire and his relay (for his truck's running board lights) won't work because the black wire "won't flow any juice"--in order to understand the real humor in my post :D :D :D
