Pinion Seal Replacement
Old May 10, 2013 | 09:36 AM
vetteguy22's Avatar
vetteguy22
Default Pinion Seal Replacement
Just noticed that the pinion seal on my 1993 ZR1 is starting to leak. Looks like a straight forward job to replace, but thought I better ask if there was something I should know before just pulling off the yoke and replacing it.
Old May 10, 2013 | 10:05 AM
WVZR-1's Avatar
WVZR-1
If it's an original gear set it's very straight forward, you need a new seal and a new pinion nut. If it's a D36 pinion nut to 200 ftlb and if it's D44 250 ftlb comes to mind. Check your FSM.
I'd inspect it maybe more closely and see if it's maybe not just the splines of the pinion flange weeping a bit. The residue will either be between the seal and flange or it will be at the nut where it meets the flange. If it's at the nut inside the flange I'd clean it well and just keep an eye on it.
If you do the seal use something to seal the splines to the pinion flange, some use RTV on just the leading edge of the flange going into the rear, some axle/wheel bearing grease, I've used the blue lube GM has for drive-line slip yokes and that is used in steering columns also. It's expensive. Very! Maybe any high quality synthetic lube or like I mentioned axle/bearing grease.
If it's a replacement gear set with "crush-collar" it becomes a bit more complicated. You'll need a "crush-collar", a pinion nut and the procedure changes accordingly.
Old May 10, 2013 | 11:05 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Most here have reported the need for both the seal and a repair collar on the pinion.
Old May 10, 2013 | 11:43 AM
garys vette's Avatar
garys vette
Default pinion seal
Replaced mine no big deal got new 44 seal took nut off big screw drivered old seal out tapped new one in, no more leaking of pinion seal.
Marked where old one was tightened too and retighten to same spot with torque wrench. Torque fell within specs.
86 vert 44
Old May 10, 2013 | 04:28 PM
WVZR-1's Avatar
WVZR-1
86 vert 44
For the price of the pinion nut I don't understand the "short cut"! The pinion nut is a "prevailing torque" fastener. The idea is a "one time use"!
Here's a D60 pinion nut. A D44 HD uses a D60 pinion nut:
Old May 17, 2013 | 08:04 AM
PAULEDWARD55's Avatar
PAULEDWARD55
The seal is leaking on my 87. I'm hoping to have the same luck as you and just replace the seal and nut. Does anyone have the torque specs for an 87?
Thanks.
Old Aug 1, 2014 | 10:29 AM
Rod LaLanne's Avatar
Rod LaLanne
Default 1986 rear end seals
Well its been 2 years since the last time I was on the forum, out of work. But landed a job about six weeks ago and of course my 86 vette is screaming I NEED PARTS AND TLC. So rear end is leaking pretty good, question is
1. How difficult is to replace the two axle, and pinion seals.
2. What is the normal cost if a shop does it.
Glad to be back
ROD
Old Aug 1, 2014 | 10:46 AM
WVZR-1's Avatar
WVZR-1
Glad to be back
ROD
The pinion seal can be done in the car but the short-axle seals require removal of the differential to accomplish the replacement. The short-axle seals generally aren't issues so I'd wash the rear down well and dry it, drive it and then re-evaluate the seal leakage at the short-axles. If you're going to the effort to remove the differential for the short-axle seals then you might as well consider refreshing the entire rear.
Is this an A4 car or a M4+3 car?
Old Aug 15, 2014 | 07:10 PM
Rod LaLanne
Sorry to take so long getting back to you. It is a R4-700, I backed the car up on eamps and crawled underneith, the axel seals look fine, but I do not have enough room to get at the pinion seal to replace it my self. thats why I was inquireing about the cost.
Also if anyone knows of a vette mechanic around Manchester NH I would appreciate the name.
ROD
To Pinion Seal Replacement
