Hello everyone. I'm a new owner of a 1990 base Zf6. 140k miles. Other than rear exhaust it is stock. It was in need of TIC when purchased in November. I have got it sorted out for the most part, but I'm still having an issue with the electric fans. The primary (driver's) fan will turn on around 230 degrees but I can't seem to get the secondary fan (passenger side) to turn on even when running the a/c. Both will turn on via the ALDL ecm code retrieval.
Any ideas? Anyone know how the fans are supposed to operate? I already checked the relays and fuse.
Don't have my FSM handy but if memory serves a particular set of circumstances must be present for the 2nd fan to operate. Something like 245+* water temp &/or excessive temperature or pressure in the AC high side line.
A jumper wire across the 2 fan relay ground wires will run both fans whenever the AC is operational or when water temp reaches 228*. With the relay mod & the AC on the water temp should stay @ thermostat opening temp.
I can't seem to get the secondary fan to turn on even when running the a/c.
Check out pages 67-0 and 67-1 in Section 8A of the FSM
There are various signals to the ECM that tell it the A/c is operating
If the ECM is not getting the correct signal to show the A/c is operating then it will not activate the 2nd (A/c ) fan
There is a A/c request output from the A/c programmer to the ECM
There is a A/c on input from the compressor side to the ECM
Possibly also check the the A/c pressure switch(s)
Originally Posted by joefriday
Both will turn on via the ALDL ecm code retrieval.I already checked the relays and fuse.
The fact both work when the ECM in diagnostic mode means all the wiring / relays / fuses / etc from the ECM to the fan motor is fine
and you are lacking a signal to operate the fan
