cat back exhaust 2.5" vs. 3"
Old May 11, 2013 | 12:23 PM
dennisd1251's Avatar
dennisd1251
Default cat back exhaust 2.5" vs. 3"
I have a '92 Vette all original equip, stock, LT1, 23k miles, 6 speed manual trans. I have been looking at cat back exhaust systems. Some are offered in 2.5" and some are offered in 3". Please explain the following:
- Is there a difference in sound between the two sizes?
- I have a 2.5" system, can I use a 3" system?
- Is there a difference in performance between the two sizes (good or bad)?
- Will a cat back exhaust change require any sensor changes or computer changes?
Old May 11, 2013 | 12:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youwont get any gain on a 3" plus it will be louder and drone
Edit- look at the size of the collector on the LTx manifold. Wont get any more air through there/size no matter how big the pipes are behind that.
Old May 11, 2013 | 03:38 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
2.5"
Old May 11, 2013 | 04:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Youwont get any gain on a 3"...
Since you essentially have dual 2 1/2" pipes your exhaust flow is good to ~1000cmf, enough to support >400chp.
Old May 11, 2013 | 04:49 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
IN THEORY....
You want the pipe size to maintain constant to slightly decreased diameter -- as gases move to the rear of the car.
Theory says this keeps escape velocity up and helps with scavenging (also so lift-off is possible).
IN THEORY....
2.5" is my vote too.
Old May 12, 2013 | 08:41 AM
TA's Avatar
TA
2.5"
To cat back exhaust 2.5" vs. 3"
