4.10 GEARS [HELP PLEASE]
Old Jun 22, 2002 | 12:28 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default 4.10 GEARS [HELP PLEASE]
Im finally going to do the gear change. Where can I get the best price? part #'s? any additional parts needed? And finally, any good local DFW shops for the install ? What does all of this usually run $$$???
thanks,
Jeff
:D
Old Jun 22, 2002 | 01:45 PM
STL94LT1's Avatar
STL94LT1
Default Re: 4.10 GEARS [HELP PLEASE] (GS345)
You can get the Dana Super 44 4.10's from Al Kindler for a little over $300/shipped.
Contact Al at USAZR1@aol.com
Old Jun 22, 2002 | 01:59 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: 4.10 GEARS [HELP PLEASE] (STL94LT1)
A complete Dana 44 pumpkin with 4.10 Viper gears is for sale in the ZR1 section.
http://forums.corvetteforum.com/zerothread?id=306237
[Modified by 93Polo, 1:00 PM 6/22/2002]
Old Jun 22, 2002 | 03:21 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
http://www.tomsdifferentials.com has a very good set of 4.11 for around 200 bucks. I have a set and they work great.
[Modified by AquaMetallic94LT1, 11:22 AM 6/22/2002]
Old Jun 22, 2002 | 08:46 PM
James94LT1's Avatar
James94LT1
Default Re: 4.10 GEARS [HELP PLEASE] (AquaMetallic94LT1)
Thats where I got mine, BTW thanks AquaMetallic for giving me the info before! :cheers:
Old Jun 22, 2002 | 10:30 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
I got mine at the Dodge dealer. They make "0" noise. I have heard that some others do after awhile. I got my speedo gear from LPE.
You will love em !!
:cheers:
Old Jun 23, 2002 | 01:50 AM
AquaMetallic94LT1
Default Re: 4.10 GEARS [HELP PLEASE] (zrracer)
You will love em !!
:cheers:
Toms makes zero noise. Richmond makes a set that is designed to be used for higher performance applications so its stronger but makes the design makes it noisy.
Old Jun 23, 2002 | 03:33 AM
The Green Rocket's Avatar
The Green Rocket
Actually, the Richmond gears are weaker than the Viper 4.10:1 gears - its all in the pinion gearshaft. Our Corvette Dana 44's use a pinion shaft size the same as on the Dana 60, the Richmond gears are true Dana 44, so they must use a pinion shaft spacer sleeve to fit in the Corvette.
Thomas
Old Jun 24, 2002 | 09:24 AM
96GS#007's Avatar
96GS#007
I bought my gears from Al Kindler and installed them 2 years ago. Best mod I ever made. I put about 2,500 miles/year on the car, including a little bit of 1/4 mile action and some autocross. I did the R&R of the pumpkin and had Chris Reinhardt's dad (Paul) do the setup for me. They're nice and quiet, no gear whine. It's all in the set-up.
You'll need the following parts...
- Gears...~$300 delivered from Al
- Speedo Correction (I used gears from LPE)....~$150 (can also use an HPP+ for ~$330 or a Cyberdyne Unit for ~$125)
- Gear Lube & GM Limited Slip Additive...~$20
- Install can be up to $600 depending on the shop.
While you're in there, it's a good time to check the u-joints (driveshaft and halfshafts), especially if you have a lot of hard miles on them and the rear shocks.
Make sure to mark the location of the camber cams or your first stop will be the alignment shop.
:cheers:
Jim Mason
'96 Grand Sport #007
To 4.10 GEARS [HELP PLEASE]
