leaky heater control valve
Old May 13, 2013 | 08:54 PM
chillin-n-killen's Avatar
chillin-n-killen
Default leaky heater control valve
my 1986 coupe has a pretty good leak at the heater control valve.was wondering if there is a rebuild kit available and if so where do i buy one. or should injust replace the whole thing { $170.00}. also is it pretty ez to do a rebuild ?? tnx in advance..............jerry
Old May 13, 2013 | 09:38 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
are you sure it's the valve and not the vacuum lines in back of it? Mice love to chew on them
Available on ebay for a lot less than $170
Old May 13, 2013 | 09:59 PM
leesvet's Avatar
leesvet
the water control valve pipe assy under the hood?
if so, new ones leak. Its NOT a 'got to have' item for the heat & a/c to work right. It just stops water from flowing to the core when the heater is NOT being used.
After 2 or 3, I took mine out and built a replacement system to accept the 1/4" line from the intake, and the 2 heater lines to and from the core. Brass fittings, a cpl barbed fittings...done. No mo leakin.
Old May 13, 2013 | 10:37 PM
BGZQ8's Avatar
BGZQ8
Did every model year C4 have one ? Have not noticed one on my 91.
Old May 13, 2013 | 10:58 PM
vetteoz's Avatar
vetteoz
Only used on early years
http://forums.corvetteforum.com/c4-t...-corvette.html
Old May 14, 2013 | 12:43 PM
DanZ51's Avatar
DanZ51
Here is the knowledge you seek:
Go forth and repair....
To leaky heater control valve
