Alternator output issues !!!
Old May 13, 2013 | 10:44 PM
RICOWEB's Avatar
RICOWEB
Default Alternator output issues !!!
Hello out there in Corvette land !!!!
My problem is a alternator output issue,i recently installed a new 383 stroker in my 1994 coupe [copper coloured ]and after getting everything swaped over to this beauty of a engine,which runs excellent,but cannot drive it until i get this charging problem resolved !!!!
I removed the alternator and got it bench tested and it puts out well,for a new alternator by the way !!!! But when i reinstalled it i only get battery voltage at the output terminal on alternator,i checked connections at fuse box behind battery whre fuseable links connect,no change, does anyone out there have any idea on whats going ,or had the same issues !!!!!
I would greatly appreciate any feed back on this problem,as i am very eager on getting this baby back on the road and check out the new power plant on my babe !!!
Old May 13, 2013 | 11:36 PM
Cliff Harris's Avatar
Cliff Harris
The alternator needs voltage from the ignition switch to enable the voltage regulator. Check those "other" wires.
Old May 13, 2013 | 11:42 PM
powerpigz-51's Avatar
powerpigz-51
I don't know about Corvettes, but on other GM's there is a fuse for battery voltage to the alternator that Cliff is talking about.
Old May 14, 2013 | 12:53 AM
leesvet's Avatar
leesvet
yep..
check the 'other' plug on the alt and clean it WELL and trace the wires back to see if one got damaged from the engine install. Its NOT UNUSUAL for a wire to get pinched during an engine drop...harness gets hung or caught under something...gets damaged as the engine is set down. Or the wires can get stretched and broken inside the loom from getting hung either lifting out or dropping in. Your alt section is right there close to the driver side motor mount...with more toward the firewall where it does get bumped around.
beyond that, the alt charge can also be effected by the quality of the wires on the jumper post if you have one. There IS a wire on the pos side of the battery OR on the jumper post that supplies the alt signal and lets it charge. Clean those well. Wire brush the contact surface then re-attach. Not unusual for a good alt to start showing <12v with engine running...when it does, its usually the connections and NOT the regulator thats failed. Simple cleaning will get the voltage back up to 14+ at start up.
Old May 14, 2013 | 12:24 PM
DanZ51's Avatar
DanZ51
After you check the obvious stuff (pinched wires, bad/corroded connections, etc.), it could be something weird. As what happened to me: as in flaky alternator (intermittent open circuit).
http://forums.corvetteforum.com/c4-t...ator-woes.html
Old May 15, 2013 | 12:59 AM
Cliff Harris
I had the intermittent "now it's charging, now it isn't" thing happen to me. The rebuilt alternator had been on the car at least 5 years without problems. When it wasn't charging I smacked it with a hammer and it started charging. I took it apart, cleaned everything and put it back together. I couldn't find anything wrong inside but it's been fine for several years since then. I guess it was a loose connection -- no way to know for sure.
To Alternator output issues !!!
