I WANT MY A/C BACK!!!!! need help!
Old Jun 22, 2002 | 04:31 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default I WANT MY A/C BACK!!!!! need help!
1990 L-98 with ECC...(electronic climate control)
I have checked for codes stored...none present....just get the 00
so...I don't have a clue where to start...if I have no codes the thing should work right?
I mean there seems to be a code for everything!...from motors not working, to low freon.....
need some help please.
jeff :cool:
Old Jun 22, 2002 | 05:15 PM
frank moran's Avatar
frank moran
Default Re: I WANT MY A/C BACK!!!!! need help! (XtremeVette)
suggestion, check your owners man and run through the reset process,
Old Jun 22, 2002 | 06:15 PM
XtremeVette
Default Re: I WANT MY A/C BACK!!!!! need help! (frank moran)
already did it frank....results..... = no good...no a/c
Old Jun 22, 2002 | 10:33 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
I just went through this. In my case it was the motor an easy fix........
:cheers:
Old Jun 23, 2002 | 02:14 AM
XtremeVette
Default Re: I WANT MY A/C BACK!!!!! need help! (zrracer)
how did you find that it was the motor....and what do you replace to fix it?
thanks
Jeff
To I WANT MY A/C BACK!!!!! need help!
