What Scan tool do you use?
Old May 17, 2013 | 11:35 AM
mxw128's Avatar
mxw128
Default What Scan tool do you use?
Just wondering what scan tool folks are using and if they like it or not. I'm thinking about replacing mine (I've got an AutoXray Techscan 7000) and I'd need a until that can handle both OBD-I and II...
So... recommendations?
Old May 17, 2013 | 01:10 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The codes for many OBD I vehicles can be obtained by using a paper clip. I know the '84 I had the codes could be obtained this way.
Old May 17, 2013 | 01:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When racing I'd used my 12yr old Auto X-Ray mostly for tuning; these days it's used mostly for pulling codes and the occasional tune check.
Old May 17, 2013 | 05:52 PM
WW7's Avatar
WW7
Well, I was going to recommend my AutoXray 6000 to you, but you already have the better 7000...I do like the 6000 scanner though.....What's wrong with the one you have???.WW
Old May 18, 2013 | 12:20 AM
mxw128's Avatar
mxw128
This is my second autoxray, I had the 4000 before ( the olive green one..I think that was the number) but it was stolen. I liked it, never had an issue. Lately though I'm seeing problems with their customer support. My 7000 isn't compatible with the autoxray pc software, they have a different program specifically for the 7000 which doesn't seem to work well with Vista. For my 94 there are some software errors with the scanner ( wrong units and things like that) so I'm not entirely confident in it. It's ok, but I'm seriously considering going back to the other model.
Old May 18, 2013 | 12:22 AM
mxw128's Avatar
mxw128
I'm looking for more than a code reader... I'd like a scanner and the ability to see and record the data stream.
Old May 18, 2013 | 02:28 AM
Cliff Harris's Avatar
Cliff Harris
Run it under Windows XT or NT in "compatibility mode".
Old May 18, 2013 | 07:15 AM
WW7's Avatar
WW7
Another option would be to get Datamaster and the connection wire to use on your laptop...I also have this setup from when I installed my 383 engine and used it to Datalog for tuning..This is the best setup as far as Im concerned...There is no handheld unit out there that will give you as much info as Datamaster, everything is stored in a file that can be saved and viewed later, and the playback speed can even be adjusted for when your having engine trouble and need to check out what the sensors are doing frame to frame...It's the ultimate scanner.....WW
http://www.ttspowersystems.com/DataMaster.html
Old May 18, 2013 | 02:12 PM
jtc44's Avatar
jtc44
Default Scanner
If you want to work on OBD 1 and OBD 2 stuff may I suggest looking on ebay for a used snap on tool. Like the mt2500(the brick) the solus or the solus pro. But know this up dates can cost big $ so get one with the latest you can. These are not just code pullers they can do so much moor. Want to know moor? Try this do a Google search for a guy called scanner danner and watch some of his vids. You might find them interesting! Good luck
To What Scan tool do you use?
