tilt steering spring/ clip
Old Jun 22, 2002 | 10:02 PM
jtfrog's Avatar
jtfrog
Default tilt steering spring/ clip
I am fixing the tilt steering play on my 86 corvette. In the process a triangle shape sring clip came out from the passenger side of the wheel when I was pulling the housing off. Does anyone know where it goes.
Jtfrog
Old Jun 22, 2002 | 10:22 PM
Rich B.'s Avatar
Rich B.
Default Re: tilt steering spring/ clip (jtfrog)
Steering wheel nut retainer??? Fits in the groove just above the steering wheel nut???
GM Safety feature...So you don't walk off with the steering wheel in your hand...
Old Jun 22, 2002 | 10:38 PM
jtfrog's Avatar
jtfrog
Default Re: tilt steering spring/ clip (Rich B.)
is this the clip deep inside behind the turn signal assembly? not the star shaped clip to hold the wheel on
jtfog
Old Jun 23, 2002 | 12:17 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Only thing I can think of is the key warning buzzer switch spring. :crazy:
[Modified by Ramrod92, 10:52 PM 6/22/2002]
Old Jun 23, 2002 | 08:22 AM
Rich B.'s Avatar
Rich B.
...not the star shaped clip to hold the wheel on
Sorry; my nut retainer is triangular...With circular indentations where the clip splits; so you can get an icepick in there to spread it...
Must be a mechanics' add-on/modification... :rolleyes:
Old Jun 23, 2002 | 11:31 AM
Corvette0096's Avatar
Corvette0096
This should help you. http://www.aros.net/~rbuck/column/tiltcol.html
To tilt steering spring/ clip
