Headlight
Old May 19, 2013 | 02:18 PM
jseremba's Avatar
jseremba
Default Headlight
Hello
I own a 1984 Corvette. I changed the gear in the headlight motor. The light goes up and down BUT, when I shut the headlight it does not go all the way closed. I turn the adjusting **** and make the headlight close. Then turn the lights on and off and it does not close. Any ideas.
Thank you,
Joe
Old May 19, 2013 | 02:32 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Was it closing properly before you changed the gear?. When you changed the gear did you remove the armature from the bottom half of the casing?? Is it running up against the stop bolt??
Old May 19, 2013 | 03:42 PM
jseremba's Avatar
jseremba
Default headlight
No it was not working before I fixed it. The motor was turning but the headlight was not moving. All I did was take the gear cover off. Put a brass gear in wear the nylon one was and close everything up. I will say that the GEAR was much harder to install than the one in the video I watched. It seemed like the insulators were too big.
Old May 19, 2013 | 03:59 PM
ccrazor's Avatar
ccrazor
This is a pic of my 84 motor, by insulators do you mean the rubber inserts in your brass gear?? Disregard the white circle, it was for another problem..
Old May 19, 2013 | 04:07 PM
jseremba's Avatar
jseremba
Default Headlight.
Sorry the car is an 84 but according to Adair Corvette it is a 1988 motor. Evidently both motors were changed out. Sorry for being unclear.
Old May 20, 2013 | 01:21 AM
Cliff Harris's Avatar
Cliff Harris
No it isn't. That's a pic of MY '86 headlight motor. ;-)
It's part of this thread:
http://forums.corvetteforum.com/c4-t...placement.html
Old May 20, 2013 | 01:34 AM
ccrazor's Avatar
ccrazor
That is quite possible, BUT it is identical to my 84 motor, only in worse shape..
To Headlight
