Cracked targa top
Old May 22, 2013 | 12:29 AM
Calgaryvettedude's Avatar
Calgaryvettedude
Default Cracked targa top
Uncovered the 86 coupe after a long winter and found a nice crack in the targa top. Pretty much dead centre of the top and runs for about 5 inches. Judging from the paw prints on the cover the likely cause is from my cat jumping onto the car from the top of my fence. Is there a way to repair the crack, I know a replacement targa will run me around $1300. Has anyone tried to patch a crack with a plexiglass glue or other type of polymer? Any suggestions or money saving ideas would be greatly appreciated.
Old May 22, 2013 | 01:33 AM
leesvet's Avatar
leesvet
Nope. Can't be done.
That "top" is actually a structural frame member...
Bolted in place it secures the frames box design to align the 2 rails...and keep it stable. Take that top off and the car looses 50% of its handling due to some serious frame flexing...expecially around corners.
There are some shops that can replace the glass. How much $$ ...I dunno.
You CAN search FleaBay and find a used one in decent shape.
Craigslist,. even local Corvette clubs will know. Look here at the "for sale" section.
Can;t blame this on the cat...sorry. Its common for tops to crack when parked if there was a wheel on a bump or the car was unlevel..placing stress on that top frame member...and it cracks. Have to be a damn big cat to break that top !
Old May 22, 2013 | 01:40 AM
Calgaryvettedude
Thanks for the advice, I'll definitely check out the for sale section. And I did have it parked on my gravel parking pad over the winter, quite un level. I was going to try Weldon 16 to patch it up but won't waste the time or money now. I guess the cat can stay!!! Thanks again!!
Old May 22, 2013 | 01:54 PM
Lingenfelter383's Avatar
Lingenfelter383
Weather and flex, that's all it takes. You can get them reglassed, I've had it done before. One hint though, when you put it back on, be VERY VERY !!!! careful about getting the fit correct. If you get it off just a little bit, it will crack again. These tops all crack at some point in their life. It's always straight down the middle front or on the back corners.
Old May 22, 2013 | 02:59 PM
lt4obsesses's Avatar
lt4obsesses
Which is why when I go to get my replaced, I'll be looking for the fiberglass top.
To Cracked targa top
