Dash Flasher Lights
Old May 23, 2013 | 07:15 AM
Waffle99's Avatar
Waffle99
Default Dash Flasher Lights
When I got the car last month, the dash flasher light did not work but all the flashers did. Then it rained and they both worked, now that is has dried out only the right still works.
What could be causing the left to not work? Again, all of the lights on the car work, just not the left dash flasher light.
I am guessing there is a bad ground or a short in the wire that got bridged by water?
Thank you ahead of time, this forum has been very helpful.
