I went to the strip last night and I did some upgrades this year and seem to loose time ?
Any ideas?
I put on
4 qa1 shocks (dialed to 0 for drag racing)
New bosh 3 injectors
new plugs
new wires
I went from my performnce chip to my stockchip
a Line lock (this was not my best idea its now a electric parking brake)
some how my best time was 14.9! last year I was around 14.5 with the egr causing detenation.
It felt like it was shifting into high gear way early. The trans fluid looks a little dark but not burnt, It did not feel like it was slipping.
I was told the track was very loose but i didnt really notice any tire spin,
Get out your best time slip from today and compare it to your best time slip from before... post both and I'll see if I can tell you whats going on.
Will
Indeed incremental times, especially short time as well as trap speed is needed.
BTW, what were air temp, RH and pressure at each event? I have equations to normalize ET & trap speed for temp & baro.
What year Vette?
1985 Stock except for the mods above and i will dig out my old slips, It was cold friday like 60-65f
last year it was much hotter in the 80's if i recall
Any ideas?
I put on
new plugs
new wires
Vet racers please educate a newb
Stock standard should be 14.5 sec quarters, fit headers open the air filter cover for more airflow and fit an adjustable fuel pressure regulator and set to 45-50 psi. that will knock a second of your quarter mile time.
Unbolt your cat and put in a straight thru pipe for the track. Underdrive pulleys will also help. These two took my 85 from 14.0 to 13.6 (automatic with 3.07 gears).
No cat, and Open pipes @ the rear via electric Cut outs
I see a blueprint engine in my future I think she is pretty tired after 28 years it may be just time to replace the motor
Will
What year Vette?
Originally Posted by ex-x-fire
What's your 60'?
X4.
We need more information. 60's, trap, etc. Post it up if you want to help us, help you.
