TBI Syncro
Old May 26, 2013 | 04:24 PM
jseremba's Avatar
jseremba
Default TBI Syncro
Hello,
I own a 1984 4spd Corvette
I tried to use a manometer to Syncronize and tune my TBI units. The fluid got sucked into the TBI units. Any help on this?
Oh and I used the WinALdl software and it did not give me any TPS or IAC information and it did not give me RPM. The system used com 4 with a 2400 Baud rate.
Thank you for the help
Joe
Old May 29, 2013 | 04:42 PM
Rohn's Avatar
Rohn
I thought thre was a "ported vacuum" nipple to use. I believe you may have used a full VAC nipple. I used a VAC gauge on mine with full VAC in that instance. Got it reasonably close. I recall 6 inch of water is what you shoot for.
Old May 29, 2013 | 07:02 PM
jseremba's Avatar
jseremba
Default TBI balance
I actually found a manometer at work so I am going to try it. But I was wondering why some one cannot use vacuum gauges. Can I use teo vacuum gauges and try to get them both at the same vacuum?
Just a thought.
Joe
Old May 30, 2013 | 01:39 PM
Rohn's Avatar
Rohn
One gauge with a couple valves and a T fitting?
Old May 30, 2013 | 03:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No, because the vacuum reading and sensitivity should be too low to see accurately on a vacuum gauge which references mercury, not water. That water manometer is much more sensitive. Rohn is right that there should be PORTED vacuum nipples to use for this.
No b/c then you'd get an average reading and you need to pinpoint EACH TB, one at a time. If you had two water manometers you could do them at the same time.
Old May 31, 2013 | 12:55 PM
jseremba's Avatar
jseremba
Default TBI Syncro
I was using a guide posted by one of the people on this forum. It actually shows in a picture and cricled what nipple to use. And it sucked the iced tea right in.
Do I need a valve on the line going to the water manometer.
Like I said I have a manometer from work, electronic. I am going to try it. But , I would still like to know why my water one failed so miserablely.
Thank you
Old May 31, 2013 | 01:03 PM
Rohn's Avatar
Rohn
How to build a manometer:
http://www.obairlann.net/reaper/moto...manometer.html
Old May 31, 2013 | 03:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thank you
I don't know other than having it hooked to the wrong port. Should need any valves in the line.
Old May 31, 2013 | 03:41 PM
Rohn's Avatar
Rohn
Is the lenght of tube in the manometer too short?
My link shows 10 feet of loop with 4 feet of water in it. 2 feet on each side.
Old May 31, 2013 | 04:43 PM
corvettenorway's Avatar
corvettenorway
http://www.thecubestudio.com/Crossfi...tManometer.htm
Old May 31, 2013 | 04:47 PM
corvettenorway
http://www.thecubestudio.com/Crossfi...eriesIndex.htm
Old May 31, 2013 | 08:48 PM
jseremba's Avatar
jseremba
Default crossfire Syncro
Originally Posted by corvettenorway
Thank you. I did not realize that I needed so much water, 4 feet.
To TBI Syncro
