Crossfire idles too high? Why?
Old May 27, 2013 | 10:08 PM
The Plastic Lizard's Avatar
The Plastic Lizard
Default Crossfire idles too high? Why?
I bored the tb to 2". Did all the other crossfire hacks for more air and fuel pressure.
now when I try to balance tb, I cannot get idle lower than 975 in gear.
the rear tb is sitting on the stop (set screw not engaged) and the plate is still not 90deg to the bore. I can get the front plate to close 90 deg.
so I don't know if there is a vacuum leak or if something is screwed up. I tried the old propane trick, but haven't found a leak yet.
advice appreciated.
Old May 28, 2013 | 10:36 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I thought that we talked about this already?
http://forums.corvetteforum.com/1583888445-post10.html
If you can't find a vacuum leak, remove the TB's, shine a light through the bore from one end, looking into the other end. The light getting past the throttle blades will reveal where your new blades are failing to seal to your new bore. HAND trim the blades and/or bore w/sand paper until the blade seats evenly all the way around the bore.
I assume that you're having this high idle issue with the IAC passages blocked off, right?
Old May 28, 2013 | 11:10 AM
The Plastic Lizard
we absolutly talked about it in the other thread, but to no avail. I took both TBs off this weekend, and i used a jewlers file to hit all the high spots around the diameter of the plate. The front TB plate will sit at 90° when the linkage to the rear is disengaged....no bind and just a small uniform amount of daylight around it.
the rear TB plate will not sit at 90° because the stop hits the casting where the rear adjustment screw is....ie, even with the screw backed completly out, the plates cannot sit flat. At first I thought it was just a bind in the plate to bore, but it is not.
Anyway, I am trying to determine if the high idle is caused by this rear TB plate not sitting 100% flush, or if there might be a vacuum leak somewhere I can't find.
I appreciate your help in the other thread...and that has led me to where I am right now.
I guess if anyone can tell me if there throttle plate sits 90° to the bore when the rear throttle set screw is completely backed out, that would be the first place to start.
Old May 28, 2013 | 11:32 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Mine didn't (sit 90* to the bore) and I've never seen any that did.
If you have one that does, it sounds to me like you filed too much off of it.
Can you put up some pictures of the things?
Old May 28, 2013 | 11:39 AM
corvettenorway's Avatar
corvettenorway
the throttle plates need to be in the right angle !!! bore out both stop screw !!!! unscrew and fit them like tom400cfi
Old May 28, 2013 | 11:45 AM
corvettenorway
do not use a jewlers file !! use sanding paper ( not thick paper ) i do not think you can make them fit 100% using a file , i know i !!!!!! tryed that !!!!
Old May 28, 2013 | 11:49 AM
corvettenorway
the plates need to be 1.023 % bigger than the hole , then you will get the right angle !!!!!!
Old May 28, 2013 | 12:11 PM
corvettenorway
read this http://www.holley.com/data/Products/...99R9978rev.pdf not for tbi but this is good reading !!!!!!
Old May 28, 2013 | 10:39 PM
The Plastic Lizard
I will take pictures by this weekend and let you see the results
Old May 29, 2013 | 12:07 PM
Rohn's Avatar
Rohn
I presume you are using Holley Dominator 2.00 inch plates?
Old May 29, 2013 | 12:30 PM
corvettenorway
2.00 inch plates in a 2.00 inch hole is to small plates
Old May 29, 2013 | 02:15 PM
The Plastic Lizard
I was using.....
Holley 26-100 - Carburetor Throttle Plate Kit; 2 in. Plate Dia
The bore is a hair under 2in. These plates did bind before closing 100% and then people recommended I sand them. When I hit the spots that were binding I could get them to close 90°.
Now I realize I have to keep them about 5° open. I will take my calipers home tonight and check the diameter of the bore to the diameter of the plates.....I really appreciate your help.
If someone has a different part number to suggest, that would be appreciated.
Old May 29, 2013 | 02:57 PM
Rohn's Avatar
Rohn
Mine were bored by a party that has done 100's. I believe Holley Dominator may in fact be larger than 2.00. That is what I was told to buy by machinist. I took apart TB B4 I shipped to machinist. So he did not address the plates. My recollection was that they fit perfectly with no binding. I dont recall sanding to fit but may have. that was 2003.
It may be they are oval 2.00 inch in width by 2.002 in lenght?
Old May 29, 2013 | 04:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That should be correct.
Old May 29, 2013 | 05:08 PM
corvettenorway
orginal plates are 46.97 mm long and 45.91 mm wide = 1.023 % !!!!!! i bored mine to 50,28 mm and used 2" plates ( 50.80 mm ) = 1.023% off ! then you will get the right angle !!! i have bored mine my selves !! on the car , and runs great !! wacuum ports are working !!! the plates are not round !!! meseure the old one and you will know !!!!!
Old May 29, 2013 | 05:09 PM
corvettenorway
http://www.convertunits.com/from/mm/to/inches
Old May 29, 2013 | 05:13 PM
corvettenorway
i used Holley 26-100 and sanded them to fit !!!!!!!!!
To Crossfire idles too high? Why?
Old May 29, 2013 | 05:22 PM
corvettenorway
if your bore are 2" (50,8 mm ) you need plates that are 2,046 inches (51.9684 mm ) to get the right angle !!!! they have to be 2" width x 2,046 lenght !!!
Old Jun 2, 2013 | 03:18 PM
The Plastic Lizard
ok, I just checked my plates....they are 2.03"
the bore is 2.011"
here are some pictures...
Old Jun 2, 2013 | 03:47 PM
ex-x-fire's Avatar
ex-x-fire
Did you reset the tps?
