Crossfire idles too high? Why?
Old Jun 2, 2013 | 03:50 PM
The Plastic Lizard's Avatar
The Plastic Lizard
Originally Posted by ex-x-fire
Did you reset the tps?
Yes.
Set top to .525
corvettenorway's Avatar
corvettenorway
2,011 bore = 2.0572 plates to get the same angle as stock !!! but i do not think they have to be 100 % the same angle !!! as long as they have a angle !!! you have to clean, clean ,clean the iac valve and the seat !!!!
Old Jun 2, 2013 | 03:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Those plates don't look wide enough to me. I see an air gap near the shaft.
Old Jun 2, 2013 | 03:59 PM
The Plastic Lizard
There is an angle with the throttle plates I didn't file.
When you say clean the iac, it shouldn't matter as these are disabled during this procedure. I have blocked the iac ports and unplugged the iacs.
I can balance both tb to one another, but can't get the idle low enough.
Old Jun 2, 2013 | 04:08 PM
corvettenorway
on full trottle are the plates in the same angle !! and yes to tom400cfi !!air gap!!
Old Jun 2, 2013 | 05:14 PM
The Plastic Lizard
There is a flat on the edges of all of the throttle plates. The throttle plates wouldn't go into the bore if they were purely round would they?
Does anyone know where I can get larger throttle plates?
Old Jun 2, 2013 | 06:25 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by The Plastic Lizard
here are some pictures...
IN this pic, it looks like there is air gap, starting about where your finger is pointing, and getting bigger toward the throttle shaft. There is some beyond the throttle shaft as will, it appears. I would sand the ends of the throttle plates perpendicular to the shaft (by the balance hole and the opposite side) and/or the throttle bore in the same area, to try to get more closure and close up that area by the shaft.
You can get bigger throttle plates from Holley. I bought 53mm/2.09" ones for mine.
Old Jun 3, 2013 | 01:44 PM
The Plastic Lizard
I just ordered 2 throttle plates that are 2.06" Hopefully that will close up the gaps a little to get a better seal, and a lower idle.
I will let you know.
Old Jun 3, 2013 | 02:07 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Are the shafts straight? Do you have any play in the TB units themselves. I had to re bush my TB's in order to get any consistancy out of the TB's. You could be leaking air around the TB shafts.
Old Jun 3, 2013 | 03:54 PM
corvettenorway
shafts straight !!!!!read this http://www.thecubestudio.com/Crossfi...eShaftArms.htm
Old Jun 3, 2013 | 04:05 PM
corvettenorway
http://www.thecubestudio.com/Crossfi...yBalancing.htm
Old Jun 12, 2013 | 08:10 PM
The Plastic Lizard
Just an update...
I figured out the problem.
when I ordered plates for the body I ordered plates for the diameter I wanted....for example I ordered plates that are 2.060 thinking that was the diameter.
It's not...the diameter of the plates is actually about 2% larger ...they are per-sized to match a 2.060 hole....2.100
So I need to order plates that are 2.060 in diameter....I'll make calls tomorrow to figure out what I need to order
