upper control arm bushings
Old May 29, 2013 | 07:47 AM
Impala Balko's Avatar
Impala Balko
Default upper control arm bushings
is there a way to get the front upper control arm bushings out without the use of a hydraulic press.... I got all the other bushings out with a ball joint c-clamp press. also does the shaft come out too
Old May 29, 2013 | 08:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://forums.corvetteforum.com/c4-t...-bushings.html
Old May 29, 2013 | 08:54 PM
Impala Balko
did you have the new ones pressed in or did you do them yourself... if you did them yourself how did you do it
Old May 29, 2013 | 08:59 PM
96GS#007's Avatar
96GS#007
Only aftermarket poly or aluminum bushings are available. They slip right into place with virtually no effort.
Old May 29, 2013 | 10:05 PM
AGENT 86's Avatar
AGENT 86
I used a press to install them.
I put a gear clamp around bushing to keep it rigid and once the lip got into bore, removed the gear clamp and finished pressing.
I supported the A arm directly under each bore, so I didn't need any jig support.
Old May 29, 2013 | 10:17 PM
Impala Balko
I hope to tackle all the bushings this weekend... the uppers are the only ones that have me scratching my head... I will try this method and I'm sure I will have questions... I heard about a freezing method should I freeze them so they slide in easier or does it not make a difference
Old May 30, 2013 | 05:45 AM
WVZR-1's Avatar
WVZR-1
I had a friend years ago that used "dry ice" for everything that required a pressing procedure. It was readily available at the time and very close to our work. "96GS#007" mentions there should be little interference so I'm maybe not following the "head scratchin" thing! What brand/material bushings did you buy?
I would think just understanding the placement of the washers and installing the bushings in the proper orientation would be all that's required.
A few years old but great snapshots:
http://forums.corvetteforum.com/c4-t...-w-photos.html
Old May 30, 2013 | 06:48 PM
Impala Balko
I got the energy suspension polyurethane bushings
Old Jun 1, 2013 | 03:29 AM
Ziggy91's Avatar
Ziggy91
I redid my entire suspension with a Prothane kit last year. Uppers had me scratching my head too, but luckily I found away. While the majority of the bushings were pushed out with a 3 ton arbor press, I needed to use the big vises on a CNC machine at work to get the upper c-arm bushings out. While I know this isn't equipment that everyone has access to, I hope the idea can spark something.
There is another member who started a thread over a month ago with your question. He was pointed to a machine shop in his area, but he's dealing with issues. I'm not understanding how because I did mine in an hour with fabrication, and have read that the process can be done in minutes by a well stocked shop for as little as $20.
Hope you can get them out. Just remember not to bend the "wishbone" part of the C-arm or you'll be in trouble.
Old Jun 1, 2013 | 03:32 AM
Ziggy91's Avatar
Ziggy91
I sketched on a picture I got off google to give you a "general" idea. I emphasize the "general" part because I've been drinking and it might not make perfect sense...
Good luck!
Old Jun 1, 2013 | 10:15 AM
DanZ51's Avatar
DanZ51
Tip: I used a length of angle iron, notched on the ends, as a brace for the upper A-arm.
A cheap hydraulic press really is the tool of choice for this project. If you don't want to clutter up your garage with one, I'd ask around to see if a buddy or local garage has one. If you got the parts (and brace) in hand it's a five minute job.
Old Jun 2, 2013 | 01:51 AM
Impala Balko
after a moment of head scratching I brought it to a buddy that has a hydraulic press I should have the a arms back on Monday with the new bushings in it ready for reassembly
Old Jun 2, 2013 | 02:14 AM
WVZR-1's Avatar
WVZR-1
The last guy that "trusted" someone else with control arms still hasn't gotten his back and it's been a month! Which Monday? He understands the assembly procedure?
Sorry just couldn't resist!
Old Jun 2, 2013 | 11:50 AM
Impala Balko
hahah I should get them tomorrow after I get out of work
Old Jun 2, 2013 | 10:33 PM
dizwiz24's Avatar
dizwiz24
) adjustable uppers, that already have alum. Inserts in them. Much less effort.
And won't squeak like polyurethane
Old Jun 5, 2013 | 09:22 PM
Impala Balko
ok so this guy couldn't get it done... someone put it in my head to burn them out with a map gas torch... is this a dumb idea or would this safely work.
Old Jun 5, 2013 | 11:42 PM
Ziggy91's Avatar
Ziggy91
Burning out old rubber will work... slowly.
But your problem isn't just getting them out, it's also getting the new ones back in.
Look at the picture a few posts up of the control arm setup and imagine squeezing those new suckers back in their position. Wana try doing that by hand?
To upper control arm bushings
Old Jun 6, 2013 | 07:37 AM
AGENT 86's Avatar
AGENT 86
Drill bit and vise grips don't stink like burning rubber
Like I said in my thread, less than 5 minutes with no chance of catching on fire or bending the A arm.
Try it
Old Jun 6, 2013 | 12:10 PM
dclafleur's Avatar
dclafleur
I like your method Agent, on a related note I picked up the 20 ton harbor freight press this weekend, I think it was $150 with a coupon, good time to buy if you're looking. I figure if I have it I'll never need it again!
Old Jun 7, 2013 | 06:44 AM
Impala Balko
Try it
I tried that and I could get that to work for me... I snapped 4 bits and gave up
