c4 to c5 brake conversion brackets
Old May 29, 2013 | 11:47 PM
87stocker's Avatar
87stocker
Default c4 to c5 brake conversion brackets
I know somewhere there was posted a cad drawing of this bracket. I have the caliper and rotors. I just need the brackets. I can build these. Can someone point me in the right direction.
Old May 30, 2013 | 10:07 PM
The Plastic Lizard's Avatar
The Plastic Lizard
I just did this conversion on my 84.... What year do you have? It makes a difference. Pm me your email and ill send tomorrow from my pc..
Old May 31, 2013 | 05:08 PM
mako41's Avatar
mako41
http://www.corvetteforum.de/userfile...6_c5-brake.pdf
Old May 31, 2013 | 10:42 PM
The Plastic Lizard
That's the 88 up.
You have an 85-87 so you need this bracket.
Note the 84s have two 12mm holes instead. Also you need to mill about 1/8" of thickness around two of the holes.
When its done it should look like this
Old Jun 2, 2013 | 06:36 PM
4lnkdsupra's Avatar
4lnkdsupra
who sells them?
Old Jun 2, 2013 | 06:40 PM
The Plastic Lizard
They are on ebay all the time. I made mine myself.
Old Jun 2, 2013 | 07:16 PM
4lnkdsupra's Avatar
4lnkdsupra
Wanna make mine?
Old Jun 2, 2013 | 10:41 PM
The Plastic Lizard
Originally Posted by 4lnkdsupra
Wanna make mine?
No can do....
No time.
Look on ebay. Search for c4 to c5 brake
Old Jun 3, 2013 | 08:07 PM
76LS1BIRD's Avatar
76LS1BIRD
I have a spare set from vettes @carlisle. Powdercoated brackets
with all grade 12.8 hardware. For 85-87 Send email address for pics.
$135 shipped
These also work with C6 base & Z51
Old Jun 4, 2013 | 03:45 PM
Crepitus's Avatar
Crepitus
$135 shipped
I got mine from Bird
Old Nov 24, 2013 | 10:36 AM
87stocker's Avatar
87stocker
Thanks for the drawing boys. Im back in mod mode and doing this is the start.
Old Nov 25, 2013 | 12:54 PM
dizwiz24's Avatar
dizwiz24
Note c5 brakes are not an upgrade over a c4 with 13" fronts (j55).
If you want to do the effort, do a c6 z06 brake conversion
Old Nov 25, 2013 | 02:46 PM
WVZR-1's Avatar
WVZR-1
I believe that when you're talking about an early car that's wrong! There's way more C5 parts available inexpensively to accomplish the task. The C6 Z06 that you've mentioned a couple times for "most" isn't either practical nor inexpensive. With any of the brake changes wheels are required so there's considerations/restrictions that apply.
Old Nov 25, 2013 | 06:05 PM
dizwiz24's Avatar
dizwiz24
I stand corrected.
My c4 world is lt1+ so i dont know what it takes to upgrade an early car. I back out of this discussion
Old Nov 26, 2013 | 12:29 PM
dt#2's Avatar
dt#2
Intl Council of Corvettes
Okay now I am confused. I too thought the c5 conversion was a upgrade on a c4. My 85 has the single piston calipers versus dual. Also I think the rotors were smaller too.
Old Nov 26, 2013 | 02:35 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
For an 85 - yep its an upgrade
For my 92 with the J55 - not so much. Big Brakes are where its at.
Old Nov 27, 2013 | 08:42 AM
The Plastic Lizard
Questions?...it is a big upgrade
To c4 to c5 brake conversion brackets
Old Nov 27, 2013 | 09:07 AM
c4cruiser's Avatar
c4cruiser
84 thru 87 C4's didn't have an optional brake package. The front rotors were just under 12" in diameter. All 84-96 C4 rear brakes were the same except for the parking brake. Prior to '88, the parking brakes was an internal drum system; '88 and later cars used the rear caliper for the parking brake.
The J55 brakes were part of an optional suspension package until about 1994. The standard rotors were 12" but they did have dual piston calipers. The larger 13" brakes were standard on all cars at that point. ZR-1's came with the J55 brakes.
So
Old Nov 27, 2013 | 09:59 AM
WVZR-1's Avatar
WVZR-1
You are NOT confused - some that have posted certainly are though.
'87 and earlier "front" calipers are single piston and the C5 upgrade is actually the only upgrade that makes economical sense. There's way more parts available and for less $$'s as a rule. A few years ago that wasn't the case. If the C6 base/Z51 calipers were available for less then that might be the choice. The brackets I believe are the same as mentioned and I don't believe it changes the wheel restrictions.
OP - you're on the right track but unless you received something more technical than what's contained in the image in post #4 I'd maybe wait and do some research for dimensions or consider a buy from someone that offers a more professional approach to the brackets. I don't know that an eBay buy is a good buy either until researched well.
The early C4 bracket seems a bit over-priced but I guess that maybe volume has something to do with that.
Something to consider is also that in some states if an inspector sees something that is "non-stock" during a safety inspection it can cause a "failure to pass" - the better the quality of the "fit and finish" of the adapter hardware could make a difference. Sometimes "purdy" matters!
Old Dec 4, 2013 | 10:01 PM
dt#2's Avatar
dt#2
Sweet, Where can I find this set up? I have been looking at Mid-America and Ecklers but I think they want too much.
