Help identifying these connectors!!
Jun 1, 2013 | 10:27 PM
Jun 1, 2013 | 10:32 PM
btw deleted cruise, EGR, went with a th350, and no smog pump!! and both plugs are identical but one makes my front ac fan stay on constant
Jun 1, 2013 | 10:45 PM
It varies depending on tire size. What year Buick is that?
Jun 1, 2013 | 10:49 PM
Quote:
Originally Posted by
Just BOB
Jun 1, 2013 | 10:57 PM
Jun 1, 2013 | 11:05 PM
Might take a day or two, but someone with an 88 will probably weigh in with an answer.
Jun 1, 2013 | 11:08 PM
Cruise-In II Veteran
They don't look familiar; what year Vette?
Jun 1, 2013 | 11:42 PM
65Z01
...what year Vette?
Might be an 88.
Jun 2, 2013 | 02:03 AM
#3 - red is cannister purge, #2 trans connector likely and #1 if you'd take the damn "fingers" off the "clue" you could be helped much easier. Post the wire colors for each and life could get good quickly. If under your thumb is yellow & purple VSS?
Jun 2, 2013 | 09:58 AM
Haha ill take better pic the connector(under tumb) in first picture... its on the same pigtail for the 2nd pic connector.. If that makes any since..
If ur saying that the white connector in second pic is tranny the the one I'm holding in the first pic is speed sensor mabe..
What's the connector coming of the positive battery cable??
Jun 2, 2013 | 10:25 AM
4lnkdsupra
Like I mentioned if it's yellow & purple under your thumb then yes VSS!
The reds from + cable, likely cooling fan relay and ecm, fuel pump and other relays likely fusible link material.
Jun 2, 2013 | 12:17 PM
Does Any of those absolutely need to be connected I'm having problems with fans coming on?? I connect the connector coming off the battery to connector closest that would make since and only the ac fan (front of the car blow) constantly blows
Jun 2, 2013 | 12:18 PM
Yup the colors are yellow n purple looks more like pink though thanks for the help
Jun 2, 2013 | 05:49 PM
Jun 2, 2013 | 05:54 PM
Better pics of connectors. I took cruise control out is that mabe a bad thing to do. is it ending a power circuit to a relay u think?
Jun 3, 2013 | 09:59 AM
Cruise control is a 'passive' system.
Removing it doesn't hurt anything.
Except maybe your tired foot after a long drive on the freeway.
