Steering noise
Old Jun 1, 2013 | 06:37 PM
scon958's Avatar
scon958
Default Steering noise
I have a 1996 m6 and my steering is making noise.
Turning off center, either way is creating this clicking noise.
Has anybody experienced this?
Old Jun 2, 2013 | 03:11 AM
Cliff Harris's Avatar
Cliff Harris
Where is the clicking noise coming from?
If it's in the column it's the turn signal canceling mechanism.
Old Jun 2, 2013 | 05:33 AM
enventr's Avatar
enventr
Many vettes have this problem.If your problem is the same as mine it is the steering knuckle (u joint) under the hood.I did try greasing it up but did not last long.I believe there was a bulletin on it.I don't even notice it that much.I don't believe new parts are available.As long as it is not very loose I would not worry about it.
Old Jun 2, 2013 | 11:41 AM
scon958's Avatar
scon958
Engine compartment area, got another reply mentioning the knuckle and I'm going to check that, thank you for getting to me.
Old Jun 2, 2013 | 11:47 AM
scon958's Avatar
scon958
I think that's it, I'll get someone to turn the wheel while I listen closer to that, thanks for reply
Old Jun 2, 2013 | 11:51 AM
enventr's Avatar
enventr
That is what I thought it was.Mine has been doing it for 8 years
Old Jun 3, 2013 | 10:52 AM
JoeUser's Avatar
JoeUser
Mine, as well ('96 vert). It feels as though it's transferring up the column, so it's likely the steering knuckle. Added to the long list of things to eventually fix...
To Steering noise
