Code Readers/Scanners?
Old Jun 2, 2013 | 07:51 PM
Donne Trav's Avatar
Donne Trav
Default Code Readers/Scanners?
What Code Readers/Scanners are you guys using on your vehicles?
I'm looking for a "good" one for under $200 for my "94 6 spd LT1.
Thank you all.
Old Jun 2, 2013 | 09:04 PM
93Rubie's Avatar
93Rubie
Under $200, good luck finding a "good" one. All depends on what you want to do. My OTC Nemisys can read codes, live data, record data, etc... in ALL the accessible modules in my 93. ECM, CCM, ABS/ASR, Air Bag.
Reading codes is kinda of a waste you can do that with a jumper wire. Spend the money to get live data and such, HUGE help if you know what you are looking at.
This is what I have:
http://www.ebay.com/itm/Nemisys-scan-tool-with-adapters-/200929474389?pt=Motors_Automotive_Tools&hash=item2ec8547755&vxp=mtr
Paid $400 about 2 years ago on Ebay.
Old Jun 2, 2013 | 09:24 PM
Donne Trav's Avatar
Donne Trav
[QUOTE=93Rubie;1584056980]Under $200, good luck finding a "good" one. All depends on what you want to do. My OTC Nemisys can read codes, live data, record data, etc... in ALL the accessible modules in my 93. ECM, CCM, ABS/ASR, Air Bag.
Thanks. I do want more than just the codes. I would like the "live data"
and records you mentioned. I just need to analyze the basics of my LT1s engine ie. fuel system, electrical system, etc. My understanding is there are a few for under $200.
Old Jun 3, 2013 | 01:08 AM
Cliff Harris's Avatar
Cliff Harris
If you have a laptop you can buy a cable for $60 - $70 and get free software to do datalogging.
Old Jun 3, 2013 | 11:57 AM
vader86's Avatar
vader86
Buy a cable and datalog on the laptop, it's cheaper and you can review it later.
Old Jun 6, 2013 | 03:07 PM
Donne Trav's Avatar
Donne Trav
Thanks, but I was told there is NO SOFTWARE for MACs.
Old Jun 6, 2013 | 04:47 PM
wschmidt's Avatar
wschmidt
Get a crappy PC. The software has minimal OS requirements, you could probably pick up a virus ridden POS on craigslist for free. The only downside is you will probably only have access to the ECM
Old Jun 6, 2013 | 04:53 PM
QZRBLU's Avatar
QZRBLU
2017 C4 of Year Finalist
I have used Diacom+ since it came out. The only drawback is that it requires a parallel port but that can be emulated with a USB>Parallel adapter. The company is no longer selling the old Diacom program so finding a copy/cables will be hit-or-miss.
Mick
Old Jun 6, 2013 | 05:05 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I have used a USB cable and an old PC with WINALDL (shareware) on it for years. My out of pocket cost was $70 for the USB cable which goes from the ALDL port under the steering wheel to my old notebook. See the attached write-up for additional details.
File Type: pdf
Old Jun 7, 2013 | 02:59 AM
Cliff Harris
I use my MacBook with Parallels and Windows XP to datalog. Works just fine.
Old Jun 7, 2013 | 03:08 AM
Cliff Harris
Originally Posted by QZRBLU
I have used Diacom+ since it came out. The only drawback is that it requires a parallel port but that can be emulated with a USB>Parallel adapter. The company is no longer in business so finding a copy/cables
Mick
Have you run Diacom with a USB parallel cable? I'm curious because I don't think it's possible.
Diacom uses a low level parallel port driver to access the port directly. It won't even run in a DOS window under Windows. The user's manual says Windows installs its own parallel port driver and Diacom can't use it.
I have an antique Compaq Presario laptop that I boot directly into DOS (NO Windows) to run Diacom+.
Old Jun 7, 2013 | 01:13 PM
QZRBLU's Avatar
QZRBLU
Cliff,
You are correct, I use that USB/FTDI adapter to run my OBDII diagnostic software. I still have an ancient IBM L40SX running DOS 5.0 and a slightly less ancient IBM ThinkPad that I startup in DOS mode under Windows 98 for my Diacom+. Too bad Ed Rinda didn't stick with automotive diagnostics and expanded into Marine and Industrial engine software.
Mick
Old Jun 7, 2013 | 01:44 PM
guno89's Avatar
guno89
Buy vmware fusion ($50) then windows 7 ($99) then you can run windows inside your mac. Or downlaod it from a torrent for free!
Old Jun 8, 2013 | 12:52 AM
Cliff Harris
I think the market for the early OBD diagnostics dried up. Besides that, Diacom is way overpriced compared to other software available now. According to my receipt I paid $585.75 for it on 5-12-00.
I talked to Ed when I bought Diacom. He told me he didn't write Diacom -- he just sold it for the programmer (he didn't tell me who that was). He told me he was having a feud with the programmer and the programmer had stopped talking with him. That's why it was never updated since the 2000 version 2.85 that I have.
Old Jun 8, 2013 | 11:42 AM
Glen Green 65's Avatar
Glen Green 65
I use a Vetronix Master Tech. It is a version of the Tech II that GM dealers use. It has software for other manufacturers. Bought it complete with GM, Ford, Chrysler and Asian cartridges for $100.00. Works well and has multimeter features.
Old Jun 8, 2013 | 12:07 PM
QZRBLU's Avatar
QZRBLU
Good info Cliff, thanks for updating us. I forget what I paid for my Diacom but it was not long after it came out. My latest version is 2.80 How much better is 2.85? Is it worth looking for the updated files?
Mick
To Code Readers/Scanners?
