[Shiftlight]: Tach Wire
Old Jun 24, 2002 | 12:09 PM
scorp508's Avatar
scorp508
Default [Shiftlight]: Tach Wire
Help me out here. :)
I am trying to tap into the white wire that comes off of C100 on the firewall for the tach input. I can find it at the connector where it comes in, but then it is wrapped up in black electrical tape only to merge with another bunch of wires. Those head up towards the right side of the dash cluster where I would expect them too. So now I have about 2 or 3 white wires of the same size. I'd rather not tap into all of them to find the right one.
Any hints? Or should I just tap into it at the distributor.
Old Jun 24, 2002 | 01:49 PM
SLEV89's Avatar
SLEV89
Default Re: [Shiftlight]: Tach Wire (scorp508)
hey scorp,
my 89 has the white wire#121 at terminal E1 on the C100 connector
this runs up to the Instrument Cluster's C5 terminal
perhaps this is of use to you?
solid state inputs - no ohmmeters!
Old Jun 24, 2002 | 01:58 PM
scorp508's Avatar
scorp508
Default Re: [Shiftlight]: Tach Wire (SLEV89)
hey scorp,
Sounds exactly the same as mine. E1, 121, C100 is the same as what my wiring diagram lists.
Old Jun 24, 2002 | 02:30 PM
SLEV89's Avatar
SLEV89
so i guess you'd have to remove your display (i know you've - been der done dat - minute stick for you!) to find this other (C5) end.
Old Jun 24, 2002 | 08:54 PM
STL94LT1's Avatar
STL94LT1
To save any confusion, I just tapped into mine at the firewall.
You'll love the shift light, I have mine set low (5200 rpm's) just to see it come on more often.
Old Jun 24, 2002 | 09:10 PM
James94LT1's Avatar
James94LT1
Default Re: [Shiftlight]: Tach Wire (STL94LT1)
I have had one for a while now and never hooked it up. Since I have MSD can I just hook into the tach terminal on my 6AL?
To [Shiftlight]: Tach Wire
