Battery help
Old Jun 24, 2002 | 12:20 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Battery help
Ok, here's the deal. If my car sits for about a week the battery will be dead. This is in my garage without the alarm on. I can charge the battery back up and it will work fine, and as long as I drive the car every couple of days all is well. The battery will show 12.5 or so volts with the car off, and the voltage reads 14.1-14.3 with the car running. Any thoughts? I'm thinking the battery is on the way out and just isn't holding a charge for very long.
Old Jun 24, 2002 | 12:34 PM
chilihed'95coupe's Avatar
chilihed'95coupe
Default Re: Battery help (EvanLT1)
Sounds to me like you have a bad cell in your battery. Go get a new one, and make sure it is a wet cell battery. Don't get a gel cell battery, they are junk. :)
Old Jun 24, 2002 | 12:57 PM
EvanZR1's Avatar
EvanZR1
That's kind of what I was thinking. Guess I'll head over to Wal-mart and get a new one. They definitely have the lowest prices around, I just replaced the battery for my Tahoe and paid $35 for one with 2 year free replacement (7 year total warranty).
Old Jun 24, 2002 | 01:16 PM
jfb's Avatar
jfb
Your battery could be ok. Remove the ground cable from the battery and put an ammeter (VOM) from the battery to the cable and wait for the courtesy lights to time out and then switch down the ammeter until you can read the leakage current. I measured my 87 last week and its 26 ma. Your battery should last a lot longer than a week with normal leakage current.
Old Jun 24, 2002 | 01:20 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Battery help (jfb)
Probably the battery. I'd just get a new Delco. The optima is fine but doesn't have any real advantages for a C4. They are best when located inside the cabin like in a C3 as they don't leak fumes.
Denney's Avatar
Denney
12.5 V open circuit and 14.2 V, give or take, while running is actually about right for a good battery. A new fully charged battery Lead-Acid battery is about 2.2 V/cell (13.2 V fully charged). However, in your car there is always a drain for things that continuously require power and thus 12.5 V is probably about right. Given your description, I would have suggested pulling fuses one-by-one to see which one may be drawing a ~little~ too much (while looking at the battery voltage) as it may be something is soft shorted.
To Battery help
