1:6 rockers
Old Jun 4, 2013 | 10:45 PM
adtbrown's Avatar
adtbrown
Default 1:6 rockers
I've read a thousand posts about people wanting to run 1:6 rockers. I know that you can, but every post that I read has someone saying that the springs will fail, and it is a bad idea in general. I am wondering if anyone has run them for a long period of time and what has your experience been with them? How was the reliability? Gas mileage? If you bought another LT1 would you spend the money to run them again? I'm thinking of running a set just to see, but I'm not interested, at this point, to rebuild my valve train to do so. Thoughts?
Old Jun 4, 2013 | 10:52 PM
aboatguy's Avatar
aboatguy
You'll probably have to change your valve springs IOT run 1.6 rockers. I've been running 1.6 rockers on my dd since 2005 but I have a higher lift cam too. .61x lift at the valve. My lt1 hits 7,100 rpm almost daily no drama.
MIke
Old Jun 4, 2013 | 11:05 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
a stock lt1 cam with 1.6 rockers is the same lift, +/-.003, as a lt4 cam with the stock 1.6 rockers. springs should be fine, only about .03" at the most more lift. that's right at 1/32". and the valve reliefs in the lt1 piston are deeper than the lt4 piston.
Old Jun 4, 2013 | 11:21 PM
Benny42's Avatar
Benny42
I ran a set on stock springs in an IROC-z from about 40k miles to 200k. At about 175k miles, it would float the valves at 4500 rpms. It was pretty tired by then. I run them on my Vette now with no issues.
Old Jun 5, 2013 | 12:19 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
It never hurts to consider changing springs every 20 years or so.
Seriously, you can (or have someone else) change springs w/o removing the heads. I'd consider that part of the upgrade...and the peace of mind you'll want when revving the snot of it -- to see how much more it'll have.
JMHO
Old Jun 5, 2013 | 02:55 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
In my prior '88 Vette I ran ProMagnums, 981 springs, 7/16" studs, Ti retainers, 10deg locks from 100k miles to >200k miles and many passes down the 1/4 mile with 6k RPM shifts and no problems.
Old Jun 5, 2013 | 07:46 AM
blackozvet's Avatar
blackozvet
I just checked the manual and they also recommend changing the valve springs every 20 years
Old Jun 5, 2013 | 11:59 AM
TBSS/85vette's Avatar
TBSS/85vette
I just finished up installing 1.5 intake/1.6 exhaust roller rockers with new springs, pushrods and seals last week. The performance increase to me is incredible. Where it's the best is what I did not expect, at 40mph and above. I have had this car since 1989 and it never moved like this and I believe the new springs hand a hand in waking this up.
Old Jun 5, 2013 | 01:25 PM
Vett1990's Avatar
Vett1990
To gain the full potential of the 1.6 rocker arm you really should consider changing your old valve springs, the mechanisms are only as strong as the weakest link!
I have 1.6 in my 383 and I have ZERO valve train issues at or above 6000 RPM. Anything above 6 Grand on a TPI engine is for nothing.
Old Jun 5, 2013 | 04:34 PM
STL94LT1's Avatar
STL94LT1
IMHO, LT1 valve springs are too close to coil bind with 1.6 rockers. Install LT4 springs with your 1.6 rockers and you will be fine.
Old Jun 5, 2013 | 09:15 PM
aboatguy's Avatar
aboatguy
Its too easy to drop a valve if you have a little coil bind...
Mike
Old Jun 5, 2013 | 09:16 PM
aboatguy's Avatar
aboatguy
But LT4 springs are different than LT1 springs.
To 1:6 rockers
