bluetooth OBD adapter
Old Jun 10, 2013 | 09:14 AM
vetteLT193's Avatar
vetteLT193
Default bluetooth OBD adapter
I have a 95 LT1... anyone successfully use a Bluetooth adapter on one of these? I am guessing I only might be OBD2 compliant, or may only get partial data.
I'm asking because I'm thinking I can get a)engine data/codes/etc. and b)I'm hoping I can hook up a digital tach by using either my phone (droid), IPad, or my Nexus 7 Tablet. the engine is in a 66 vette so the tach doesn't work.
Old Jun 11, 2013 | 12:58 AM
Cliff Harris's Avatar
Cliff Harris
The only Bluetooth adapters I've ever seen were for OBD II only.
Old Jun 11, 2013 | 01:20 AM
WVZR-1's Avatar
WVZR-1
This one has been around for some time:
http://www.reddevilriver.com/ALDL_Bluetooth.php
Red Devil River is generally quite well thought of. An acquaintance with Lotus requirements speaks well of them. If you check their web-page you'll see they mention ANDROID soon and I'm quite confident that they could accomplish the Bluetooth NOW for a tuning requirement. You mention '95, are you using the '95 ALDL also? If you're actually using the 16 pin ALDL I believe they could assemble the Bluetooth for you. Engine codes and diagnostics shouldn't be an issue. The tach would be a complicated display until the Android were released I'd think.
Old Jun 11, 2013 | 12:55 PM
vetteLT193's Avatar
vetteLT193
I stumbled upon that one on eBay. I wonder if it's worth swapping ECM's out for a 96 and then going the OBD2 route Vs. only having limited software for OBD1.
Old Jun 12, 2013 | 12:50 AM
vetteoz's Avatar
vetteoz
No because the OBDII has a sh*t load of extra stuff you don't want.
Many serious '96 owners convert back to OBDI for the simpler operation
Old Jun 12, 2013 | 02:17 AM
Cliff Harris
That's interesting. I never heard of that one before. It's not at all clear if it can switch from 160 baud to 8192 baud on pin E, which my ECM (1227165 -- used from '86 through '89) supports.
Old Jun 12, 2013 | 05:09 AM
WVZR-1's Avatar
WVZR-1
It certainly appears easy enough to ask them the question. Everything they do seems to be very straight forward and they do some very specialized products.
Old Jun 12, 2013 | 08:19 AM
vetteLT193's Avatar
vetteLT193
They have an ad on ebay, try to find it, and it has more info than the web site... well, actually, different info. The ebay ad plus the website seem to be the complete picture.
I messaged on ebay and haven't heard back yet.
To bluetooth OBD adapter
